ECU for 96 del sol motor
i have a 96 ek hatch with a jdm b16a i got reffe'd i got the list form the reff of things i need to change it says i need to "install the OBD II ECU for this 1996 Del Sol B16a DOCH VTEC motor" ive come across an ecu off a 00 civic si will that work or what can i use?
also anyone selling a "throttle body with map sensor on top" or can some one point me where they sell them cheap and i also need a cat and charcoal canister
thanks
thanks
Re: ECU for 96 del sol motor
the 96-97 b16 del sol would probably be ok, or you could get the jumper for obd1 and that will give you a lot more options of ecu's.
Seagull Management
Del Sol Sis didn't come with a B16, the Del Sol VTEC did though. They used a P30
They did believe it or not, they were used only in the '96 - '97 Del Sol Si, don't ask me why though.
That is true, must come from a '96 - '97 Del Sol VTEC, good luck finding one.
Some are OBD1, some are OBD2. '96+ are OBD2.
No.
They are.
No.
They are.
No.
They are.
No.
They are.
i need a cat which one is it like this one http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories or like this one http://cgi.ebay.com/ebaymotors/Magna...Q5fAccessories
the first one wont work...that is not for a b16a...only the single slammers have the catalytic converter in the manifold.
it would work...obviously you would need to get it welded to some flanges or to your exhaust...and if youre worried about emissions, i am not sure how it would do. but i understand that oem converters are like a bagillion dollars...
gentinphilly
10-09-2010 05:13 PM
