Reset ECU? H22a swap 96 civic
Old 05-05-2009, 06:29 PM
Dr.green's Avatar
Default Reset ECU? H22a swap 96 civic
Im trying to finish up my project, just started the engine and I got code 12, 14, 16 and 61.. now after a while the redline is 2500-3000rpm.
Im trying to fix the codes, but it stays the same, do i need to reset my ecu to se if something have been solved?
I tryed to reset the ecu but its still the same, I dont know if I get it done proparly, I have been trying allot of differnt ways. what's the right one? Is it some other way to do it when you swap the obd1 eingine?
I removed the battery, clock fuse under kickpanel, jumper plug, disconnected ecu, waited for 10 minutes.. the codes even comes up when the ecu is disconected, when i have ignition on, and engine running.
I am a bit comfused and im not the biggest expert either.
I also get code 18?? cant find out what that means anywhere...
By the way the car is also turboed..
Please help me out, so i can get this thing running soon!
Old 05-05-2009, 07:26 PM
Blown90hatcH's Avatar
Default Re: Reset ECU? H22a swap 96 civic
Are you sure you are reading the codes correctly? Have you trouble shot to confirm that the codes are either valid or false? You only need to disconnect the battery for a few.
Old 05-06-2009, 12:10 AM
Dr.green's Avatar
I guess so... long are 10's and sort are 1's right? but its my ABS light thats blinking and shows them.. im pretty shure the codes are valid, they are resonable all of them, but not 18 thow.. they are still there even after I reset and just leave the ingition on...
thirsk66
24
08-11-2011 04:09 PM
gsrboost
04-16-2005 08:51 PM
ludatic
11-02-2003 10:46 PM
kim_2_da_chee
05-30-2003 06:18 PM
Quick Reply: Reset ECU? H22a swap 96 civic
