Converting a B16A into a B18C
Old Jun 3, 2009 | 07:11 PM
bsmith100's Avatar
Icon2 Converting a B16A into a B18C
I have a B16A that I want to get rebuilt.
I have also been thinking about a B18C swap instead.
However, then I had another thought. What if during the rebuild, I switched to a B18C block and crank? Then wouldn't I basically have a B18C engine (except for the B16 head)?
Or are the B18C pistons and rods also different?
Old Jun 4, 2009 | 01:24 PM
vue-k's Avatar
Default Re: Converting a B16A into a B18C
just get the complete b18c swap
Old Jun 4, 2009 | 01:48 PM
tougetuned_ef's Avatar
i dont know to much about what pistons go with what blocks but you will prolly run into valve clearance issues. plus you could just buy a b18 block for about $150 and throw that b16 head on top.
Old Jun 4, 2009 | 02:42 PM
philafelman's Avatar
ls/vtec with p30's maybe? that sounds like the best bang for the buck.
Old Jun 4, 2009 | 07:55 PM
bsmith100's Avatar
I did some research on my own. The pistons are the same. The rods are different. So once I get a B18C block, crank, and rods, then I can put the B16 head on it. Then I have a B18C more or less.
Or am I missing something?
Old Jun 5, 2009 | 04:09 AM
kyden's Avatar
pistons are definitely not the same. why not just get a complete b18c shortblock?
Old Jun 5, 2009 | 01:07 PM
bsmith100's Avatar
I'm not sure if the stock pistons are the same. Wiseco lists the same pistons for the B16A and B18C , so they can't be much different.
I will probably end up getting a B18C short or long block unless I can get a deal on a B18C block and crank. Then I would go with forged pistons and rods.
xkjnboix
Mar 14, 2016 06:16 AM
Deetz
Dec 30, 2003 05:38 PM
92TypeR
Feb 10, 2003 03:51 PM
My Documents
Jul 19, 2002 12:24 PM
ekekek
Feb 7, 2002 10:00 AM
