twm itb help!!!!!!!!!!!
Old May 10, 2009 | 03:23 PM
EG2_KING's Avatar
Default twm itb help!!!!!!!!!!!
i purchased some twm itb's with no injectors and soon after i bought some rc injectors the problem is that the rings that go on the itbs themselves dont have enough pressure meaning they dont hold pressure when i put the injectors im not sure what to do any help is good thanks
Old May 10, 2009 | 03:51 PM
deafy's Avatar
Default Re: twm itb help!!!!!!!!!!!
i'm assuming the ITB's were designed to fit factory injectors. In this case, you have probably a gap the same thickness as the injector o-ring?
Old May 10, 2009 | 04:52 PM
WhiteSol's Avatar
Are you referring to the o-ring at the top of the injector, the part that seals the injector in the fuel rail?
hoskos
Aug 27, 2007 11:22 AM
PnkRokCountryboy
Apr 13, 2006 02:45 PM
livinlow
Feb 10, 2006 07:22 PM
Vtec92Civic
Apr 8, 2004 12:59 AM
BoostedsiR
Jan 28, 2004 06:48 AM
