lsvtec coolant problem
Old Jun 28, 2009 | 04:10 PM
jaron_cc's Avatar
Default lsvtec coolant problem
Recently completing my lsvtec one of the coolant lines is giving me an hard time. After some searching i found out that the thermostat case is different from the case on an gsr it's missing the nipple that accepts the hose from the ....water outlet cover ( relate to photo number one).... so after some head scratching i ran out an grabbed me a tee fitting to tie in this hose which has no home, (relate to photo two) problem here is that under power the water outlet hose releases way to much coolant and im worried it may screw with my idle or such. or should i order an gsr thermostat case (ive never heard of any one doing this mention swaping over there thermostat case lol help me plz
Old Jun 28, 2009 | 04:58 PM
philafelman's Avatar
Default Re: lsvtec coolant problem
could you just cap it off?
Old Jun 28, 2009 | 05:04 PM
jaron_cc's Avatar
i don't thinks so, i did a quick test and left the hose loose while the car warmed up and while giving it gas it surges out like crazy (coolant) but i don't think a cap would hold
Old Jun 28, 2009 | 05:36 PM
a cap should hold with a clamp...it only sees 15-16psi. does the ls waterneck bolt up by chance?
Old Jun 28, 2009 | 05:40 PM
jaron_cc's Avatar
i don't think so, i had to order the gsr one but i'll try to clamp it off tomorrow and see if it holds
Old Jun 30, 2009 | 05:04 PM
omgwtfbbq's Avatar
I had that same hose teed between the TB and IM line with a brass Tee....never leaked under high pressure or heat, even @ 10psi boost. Yours doesnt seem to have the same barb coming off your IM, so I'm guessing you have an OBD2 motor.
IDK to be honest, but that's how mine worked.
Old Jul 1, 2009 | 08:02 AM
boost should not have any effect on coolant pressure. if it does, you have problems.
Old Jul 1, 2009 | 08:47 AM
kyden's Avatar
isn't that hose supposed to go to the fitv?
Old Jul 1, 2009 | 09:56 AM
omgwtfbbq's Avatar
I know....By saying that, I was implying that I drive my car harder than most people drive their DD's....and if my Tee held up under constant high rpms and temps, his should too.
Maybe I should have just said on my "race car" it held up just fine.
Don Jefe
Aug 25, 2008 02:00 PM
Robstunner4
Nov 1, 2006 07:27 PM
EARLdaSQUIRREL
Dec 1, 2005 04:30 PM
tFUnK
Jan 2, 2003 12:56 AM
