ls vtec headstud thread
Old Jul 1, 2009 | 04:32 PM
AJxr's Avatar
Default ls vtec headstud thread
so everyone knows that you are supposed to use GSR headstuds when doing an lsvtec setup.
i put my last lsvtec setup together using b16 arp headstuds and had no problems. ive also found a few other people doing it.
i installed them just like any other time, with an allen key into the block, then put the head on and torque.
i was wondering if anyone here had actual dimensions of the gsr arp headstuds, i have my b16s right here and ill measure em up in a second.
im looking for overall length, and length of the bottom set of threads and top set of threads. thanks.
Old Jul 5, 2009 | 09:21 AM
AJxr's Avatar
Default Re: ls vtec headstud thread
...anything
Old Jul 16, 2009 | 11:57 AM
Rease3's Avatar
bump for answer.
Old Jul 16, 2009 | 11:10 PM
isl_cruiser's Avatar
check at local parts stores and measure them there
Old Jul 17, 2009 | 06:46 PM
BigJ5's Avatar
You match the headstud kit to the head your putting on the block.
GSR studs have 2 longer ones in the centre from what I can remember. Although it has been 5 or 6 years since I touched a gsr.
Old Jul 18, 2009 | 12:40 AM
JDM JEFFREY's Avatar
wrong the ls has two longer ones
the gsr studs are longer that why you should use them for an lsvtec I've used the b16 studs in the past and they work but not if your useing a gsr head....
Old Jul 18, 2009 | 05:32 AM
Skunk2R's Avatar
The b16 headstuds and b20(ls)headstuds are next to me now.And yes ls and b20 has 2 longer studs ...
Acura_I-RS
Sep 10, 2005 05:45 AM
TurboCoop
Jul 11, 2005 09:10 PM
1SlowSi
Apr 15, 2005 01:58 PM
Vtak
18
Feb 2, 2005 02:17 PM
7rrivera7
May 24, 2003 04:29 PM
