ls vtec help (dowel pin question)
1 Post
so i started to get my motor together and when i was putting the dowel pins in i noticed that 1 dowel pin was bigger then the other. the bigger 1 fits snuggly in the block but wnt go over the head gasket.The smaller 1 fits in the block loosely and the head gasket DOES fit over it.
its a golden eagle kit that i bought a long time ago.Can i bore out the head gasket hole or do i need new dowel pins? the head gasket is OEM
Re: ls vtec help (dowel pin question)
are you putting them on correctly?
bigger side to the head, smaller side to the block.
If you need to you can bore open a little the gasket.
Have you contacted GE?
You need LS/VTEC dowel pins. KMS used to sell them. You can get them on EBAY
Last edited by 92civlude; 05-15-2009 at 01:36 PM. Reason: Sorry. You get it. I didnt read your question all the way
1 Post
yea i put them in right and they are LS vtec pins....i got them to work took the head gasket to the drill press and took the hole out a lil bit to get it to work
1990hf
05-20-2008 06:56 PM
