b20 vtec Quick Question
Old Jun 17, 2009 | 09:08 AM
civicegsick's Avatar
Default b20 vtec Quick Question
yea i have a b20 vtec hatch and i recently put it together...the block is stock and the way i got it is the way i put the head on it supposedly i had 45k the head is a port n polished b16 it has aftermarket valve springs and retainers skunk 2 stock comp valves oem head gasket ...so now to the question i was wonderin if i can put stage 1 tuner series skunk 2 cams on there w/o smakin the valves i will be takin it up to 8.5 after it is fully tuned i used to have another similar set up with type r cams and it was always fine...but i kno the stage ones are a lil more aggressive so i just want to make sure..THANX
Old Jun 17, 2009 | 08:59 PM
b20c's Avatar
Default Re: b20 vtec Quick Question
youd be really safe with 2.0 itr or p30 style with the right valve reliefs. Im runnin a b20vtec with r head cams and tranny its fine. I think the tuner series stage 1s are almost like an CTR cam. U should b fine, but i wouldn't go bigger without the right valve reliefs.
Old Jun 21, 2009 | 12:55 AM
*** it imma just put them on if i blow up il just build it...thanks for the reply tho
Old Jun 21, 2009 | 09:32 PM
string's Avatar
Clay the pistons and run the engine through a few revolutions with the head on but not fully torqued. That way you'll know if they're hitting or not. Considering that it'll take you 15 minutes you'd be mad to waste a headgasket and all the time putting it in only to find that you've bent all your valves.
Old Jun 27, 2009 | 06:14 PM
unusual71's Avatar
stock B20 bottom end will not enjoy 8.5k rpms. maybe once or twice but after that it will say thanks but no thanks and let go.
กก4drWHORE!!
10
Aug 3, 2009 07:27 PM
civicegsick
Jun 17, 2009 09:06 AM
Mr. Samurai
14
Jul 3, 2004 03:47 PM
2 0 3
Aug 17, 2003 06:45 PM
dtzvtec
Jun 3, 2003 09:28 AM
