H-series into EK tranny mount issue
I've got a 97 Civic EX Coupe that I'm swapping an H-Series into it using an H23 tranny. I don't know what brand mount kit I have but it has the crossmember for the front mount as well if that helps. My issue is that the tranny mount does not sit flush on the tranny. The studs don't sit at the same height for those who are familiar with the shape of the tranny/factory mount, as well as there are two bolts on top of the tranny right under the center of the mount that it seems to come in contact with. I'm not sure what the bolts are for but they have springs inside of them. I got the mount kit used so I don't know if it was supposed to come with spacers of different studs for the tranny. If that doesn't make since I can upload pictures later. Any help/advice would be greatly appreciated. Thanks...
Re: H-series into EK tranny mount issue
Anyone who has put an H-Series into an EK Civic? Did your tranny mount sit flush on the tranny or did it come with some kind of spacers or special studs? I'm sure I can fabriacte something I'm just not sure how high off the tranny the mount should sit. I've searched and I haven't found any mention of issues with the tranny mount for an H into a Civic but I also haven't heard any mention of the hardware that might come with the mount kit. I know there a million Civics running around with H-Series in them. Any help would be appreciated...
Are these mounts silver with red polyurethane bushings? If so they are enjo, possibly the only kit I have heard of that uses a front crossmember mount with the H22. Pictures would help, but it sounds as if the mount was not designed correctly OR alternatively, the mount is designed to be used in conjuction with spacers as you've figured out. The two bolts you are refering to are the "ball spring setting screws" (detents) for the shift forks, don't remove them.
These are the mounts I'm referring to.. but in the picture it shows the mount is made correctly.. so I dunno.
