Code 8, No Start
Old Jun 30, 2009 | 11:45 AM
DEIVIONCRX's Avatar
Default Code 8, No Start
Motor is a 100% fresh rebuild, 0 miles, B18A1. Car is wired 88-91 OBD0. Using Rywire ECU Jumper to go OBD1 with a OBD1 distrubitor, OBD0 injectors with the resistor box.
Engine cranks good and strong. After 5-10sec of cranking it throws a Code 8, TDC. I checked the sensor at the distruibutor its good 389ohm, and at the ecu again 389ohm. So the sensor and wiring is good.
Only possible problem i can think of is, cam timing off somewhat, or the Rywire harness might be missed pinned.
And it wont start, because the injectors arent firing. Its got spark, but no blinks on the noid light when cranking. Ive got 12volts at the injector, and the signal wire from the injectors to the car harness is intact and good, i didnt change the car harness so it should be good to the ECU.
Anybody have a problem similar, or know what might be wrong.
aznwash3wboi
Sep 25, 2009 11:40 AM
DEIVIONCRX
13
Sep 17, 2009 11:23 AM
HondaFerris
19
Jul 10, 2007 12:17 PM
ruby civic II
May 27, 2004 06:09 PM
Seraph0
Feb 29, 2004 10:12 AM
