awd question
Old Jun 22, 2009 | 03:28 PM
integraturbo96's Avatar
Default awd question
I have heard that the viscous coupling on honda awd system is a piece of crap.
Does it have a solution to replace him.
If I put a direct drive shaft, does it really affect driving on snow and on road.
I think the car will jerk a little bit with a direct system and it will be a problem because the car will be a winter beater.
I need a solution before buying my crv drivetrain
Old Jun 23, 2009 | 04:30 PM
TunerN00b's Avatar
Default Re: awd question
Honda AWD (SH-AWD) does not include a coupler, you're thinking of the RT4WD system.
Without it, its full time 4WD. You'll need to scrub tires to turn. Its not the best thing to drive on pavement, but is fine in the dirt/snow.
Old Jun 24, 2009 | 04:56 PM
ok and does the 4wd system on a CRV is debraillable.
I will only engage it when it snow
Old Jun 24, 2009 | 07:34 PM
Jaker's Avatar
No, the drive to the rear diff on the CRV drivetrain cannot be disabled, unless you remove the driveshaft. On the Civic Wagon there is a small lever on the transmission that can be moved from 2WD to 4WD using a 10mm wrench. The CRV does not have this capability inside the transmission.
Old Jun 27, 2009 | 07:58 AM
anyone have trouble with de VC on big hp honda?
I have heard that the VC tend to slip but I want a solution.
Probably a good maintenance on the VC just like put new fluid in it will help but I need to have a confirmation before buying my kit.
I want to run about 400bhp
Old Jul 1, 2009 | 12:18 PM
Sobe_Death's Avatar
The coupler is, by design, meant to slip a little. you will not be able to refill the fluid either.
Old Jul 1, 2009 | 03:45 PM
ok thx for the reply, I still have some doubt for the coupler but its too late to go back, Monday I have bought my Crv trailing arm, differential and 2 short axle and my friend will give me 2 spare civic trailing arm to start the project.
I will do a thread of my built if it someone is interested
rmrzdnny
Honda CR-V & Element
Jun 16, 2019 05:36 PM
slovegrove
Honda Insight & CR-Z Hybrid
Mar 15, 2017 04:38 PM
Will Gardner
Honda Civic (2006 - 2015)
Oct 24, 2015 05:24 PM
flip888
Feb 26, 2009 03:30 PM
carksi08
Aug 22, 2008 03:05 AM
