hesitation problems and solutions?
Old Sep 24, 2002 | 05:52 PM
civilude92's Avatar
Default hesitation problems and solutions?
i have recently swaped a h23a1 into my 92 civic cx. but it is a bitch to drive. i have the stock(prelude) fuel rail, injectors, pressure regulator,and feul pump. but my gas pedal seems like it isn't working right. it idles fine, butwhen i floor it it will cut off. if i don't give it enough than it will just sit like it's idle. no matter what gear if i don't push it just right than it won't do any thing. but if i hit the spot it accelerates. just wondering what it could be. i am running the civic throttle cable. but i have the lude cable, just wondering what i should do from here. oh the air fuel guage reads lean when this is occoring. at idle it's normal and when i hit the right spot it's normal too. please help! sorry for the long post.
Old Sep 25, 2002 | 03:13 PM
Lynx's Avatar
Default Re: hesitation problems and solutions? (civilude92)
I have the same problem with my Teg, but I have never fixed the problem.
Some things you may want to check out and probably need to be replaced anyway:
Fuel Filter
Plugs
Wires
Check Timing
PCV Valve?
I have replaced them all to no avail, but I may have a different problem than you do. Also look into testing your 02 sensor.
Old Sep 25, 2002 | 06:40 PM
civilude92's Avatar
Default Re: hesitation problems and solutions? (Lynx)
done them all just like u no fix. i really need help! i can't drive the car it is so bad and i just finished the swap.
Old Sep 26, 2002 | 09:32 AM
enhancedCL9's Avatar
It could be alot of things. But first check all your Distributor components that will cause a bad hesitation! Also your 02 sensor. If that dosen't work i would upgrade your fuel system? maybe not enough being flowed to the motor like PSI? Fuel pressure regulator and fuel rail would do.
Old Sep 26, 2002 | 11:47 AM
blackturtle916's Avatar
Default Re: hesitation problems and solutions? (thizguy)
is your ECU throwing codes?
Old Sep 27, 2002 | 08:48 PM
civilude92's Avatar
Default Re: hesitation problems and solutions? (blackturtle916)
yes a fuel system code 43
Monstarrr*
12
Jul 11, 2011 10:13 AM
Doug_I
Classic Hondas
Mar 5, 2010 07:27 AM
BlueRSTEg
Jan 10, 2010 10:13 PM
TRIGA
Dec 2, 2009 05:49 PM
ttracing03
Mar 6, 2005 04:32 PM
