b16a2 block with gsr crank?
is it possible to put a gsr crank, rods and pistons in a b16a2 block therefor making it a 1.8? or do you need some kind of custom rods. ive heard some different things but i wanted to see if anyone has ever done this or know if it can be done. thanks.
Re: b16a2 block with gsr crank? (sean)
I believe this would be considered Stroking the motor and I'm not sure since the b18 block are taller becasue of the bore and stroke is bigger.
Lee
Lee
Re: b16a2 block with gsr crank? (97EXhybrid)
If you use the GSR rods I believe it will fit. The B16 has longer rods which is why the deck height is different.
Re: b16a2 block with gsr crank? (Jackson)
thanks, but damn. i have all these parts available to me from friends, guess i should just buy a whole new block.
Try and locate a bare b18c block case. They usually go for a couple of hundred. Maybe even a b16b blockcase. Put all of the 1.8 internals in there. *B16b,B18c blocks are the same.*
[Modified by Jackson, 12:31 PM 9/24/2002]
weiRtech
08-24-2006 11:00 AM
