99 B18B into 95 LS
99 B18B into 95 LS
Possibly doing this swap soon.. Getting longblock only. LS is OBD1.. the 99 is OBD2 - will I run into any major wiring issues or will it be straightforward swap. Thanks.
Re: 99 B18B into 95 LS (deception23)
Just use your engine harness, ecu, distributor and injectors and everything will be plug and play. You could even use your intake manifold for a cleaner look since the OBDII has extra sensors.
MugenGTR
03-24-2002 08:18 AM
