high compression tuning
Old Sep 17, 2002 | 09:44 AM
SSBP DC2's Avatar
Default high compression tuning
this is to those who are running high compression hybrids (11:1 and up)
what are you using to run reliably?
are you on pump gas for daily driving?
what have you done to your ecu? fuel delivery? timing? etc....?
i'm planning on running a compression of about 11.3:1 with LS block, B16 head and pistons, itr cams, and possibly str cam gears (i figure they'd work the same as aem or skunk2)
what else would i need to add to this setup for a reliable motor?
thanks
-Demitri
Old Sep 17, 2002 | 12:36 PM
miller's Avatar
Default Re: high compression tuning (NA builder)
you will be fine with 93 or 94 octane, skunk 2 ecu's are nice and gat a v-afc.
[Modified by vtecdoc, 9:36 PM 9/17/2002]
[Modified by vtecdoc, 9:37 PM 9/17/2002]
Old Sep 17, 2002 | 07:48 PM
TREVER's Avatar
with good tuning...
If your going n/a 12.5 is good on 91 pump gas.
11.1 is low you can run 87
Old Sep 17, 2002 | 11:53 PM
SSBP DC2's Avatar
Default Re: high compression tuning (TREVER)
i dont think i'll have the money for a skunk2 ecu...i think i'll probably get an si ecu and chip it with hondata or something...any other suggestions?
Old Sep 18, 2002 | 04:46 AM
bikeboy80's Avatar
with good tuning...
man thats got to be some damn good tuning, I won't dare run less than 93 on my 11.3:1
Old Sep 18, 2002 | 11:26 AM
blundar's Avatar
Default Re: high compression tuning (bikeboy80)
You're an idiot if you buy a skunk2 ecu. They are junk. Overpriced JUNK.
"One size fits all" tuning is not tuning. Don't believe the hype. Running a Skunk2 ECU with a Skunk2 block, Skunk2 ported head, Skunk2 valvetrain and Skunk2 cams MIGHT make sense, however I still don't have much faith. The Skunk2 is a rip off of the Mugen ITR race platform, with RPM, vtec and fuel/timing maps changed. You can do better on your own.
Hondata, a WBo2 meter and some dyno time would be a very good idea. Hondata make a very very high quality product that is actively supported. If you have the money, by all means get one. You will have a lot more room to tune with one as you're pretty much limited to a FPR and turning the distributor without a hondata.
If you're on a budget and willing to learn a lot, check out http://pgmfi.crx-forum.org and http://www.diy-efi.org to learn more about what can be done with stock honda computers, tuning and general ECU theory.
Old Sep 19, 2002 | 02:21 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
u dont have the money for a skunk 2 ecu(250), but u have the money for a stock si ecu with hondata(550)???
Old Sep 19, 2002 | 07:41 PM
kidkombo's Avatar
Default Re: high compression tuning (SIXTYdashONE)
true huh? ask kenji on this forum, i heard he makes some bomb computer programs...and also check out vtecfrog.com, they got some stuff u can look into. hope this helps
toto
Old Sep 20, 2002 | 01:10 AM
00 FBP ItR's Avatar
you crazy trever??? 12.5 on 91... 91 is barely enough for 11.1 CR i would say 93 fro 11.1 and up... 87 for 11.1??..haha.. thats alot of knock.. and big time detonation..at high rpms..
Old Sep 20, 2002 | 07:13 AM
TREVER's Avatar
Default Re: high compression tuning (00 FBP ItR)
My roomates car is 12.8 and runs on 91 allday for allmost 2 years now.We have many customer cars running 12.5 plus on 91 no problem.I have never had to repair a n/a honda motor due to knock.Tuning is key, were not dealing with caveman domestic technology here.
Old Dec 28, 2002 | 02:34 AM
GapxGuy's Avatar
Sushi Buffet Champion
So is 12:1 CR safe with 91 octane?
this_256
Aug 11, 2009 12:20 PM
Evolsport
Jul 17, 2009 12:44 PM
bswain22
21
Sep 27, 2007 07:05 AM
boostedblack99
Jul 27, 2004 08:18 PM
