code 4 crank angle sensor????????????????????
Old Sep 19, 2002 | 09:16 AM
mraudio13's Avatar
Default code 4 crank angle sensor????????????????????
ok this might be a bit lengthy but please bare with me. i put a b16a (jdm) in my 88 civic hatch. the car starts but i get a code 4 crank angle sensor and car won't rev past 3000 rpm. I sent the distributor back and got a new one and still the same thing. I have double, Tripple, and Quadroople check my wiring and i know it is right. Is there anything else that can cause this code, I.E. map sensor, timing? PLease HELP Before i run my car off a bridge.
matt
mraudio13@aol.com
Old Sep 19, 2002 | 10:01 AM
mraudio13's Avatar
Default Re: code 4 crank angle sensor???????????????????? (mraudio13)
ttt
Old Sep 19, 2002 | 11:27 AM
Mikey3000's Avatar
i don't know about wiring for that sensor but i can contribute a bit to help you. no other sensor can cause that code, to answer that question. are you sure it's a code 4? 4 short blinks?
Old Sep 19, 2002 | 12:33 PM
Mikey3000's Avatar
i think i may have found your problem. i just stumbled into this as i was surfing. this is from a dude on hybrid honda website.
I finally got my (insert 5 minute rambling of every curse word known here) Code 4 fixed!! Details below for future reference!
Symptoms:
Engine won't rev over 3,000 ( 3K ) RPM, ECU is cutting fuel and/or spark in safety mode
Studdering idle
Timing essentially zero BTDC unless distributor is moved to full advance location
No timing advance when reving engine
Code 4 crank position sensor on ECU
Very low power
Attempted Fix:
pull "B" connector from ECU and check for 350-500 ohms between B10 and B12
- 360 ohms, passed (if fail, replace sensor or distributor)
check B10 to ground and B12 to ground
- no conductivity, passed (if fail, replace wire shorted to ground)
double check continuity and order of all wires from distributor harness to ECU
-all good conduction and proper location to ECU
Run auxillary ground wires to valve cover, head, dizzy body, intake manifold
-no help
Double check crank/cam timing to make sure belt is not off by a tooth
-spot on, no trouble there
Replaced dizzy with 91 integra, cut off one leg to fit
- still no help
Swap integra internals to B16 case
- still no help
Replace ECU with second unit
- still no help
Run computer data grade shielded wire from distributor plug to ecu plug
- PROBLEM SOLVED!
Now here is the kicker...I've been soldering and splicing wires longer than some people on this list have been alive. I was extremely careful to make sure each splice was well soldered, wrapped with heat shrink tube, and in the case of the shielded wires, I peeled back the outer casing to expose the shielding mesh and wrapped a conductive layer of aluminum over my splice to make sure the shielding was continuous. Remember, my wiring DID pass the Helms test for conductivity and shorts to ground as stated above.
At first I thought that the crank angle sensor (crank position sensor) was just extremely sensitive to radio frequency noise. I pulled the grounds for the shielding on my new wire and it still would not set a code! I don't know what the heck was going on inside that wire bundle, but what ever it was the ECU did not like it!
SO, all you peeps out there with the "won't rev past 3k" syndrome, be highly suspicious of that wire if you are setting a code 4. Even though the resistance numbers may check out, there could be some monkey business going on under the insulation. Especially if you have made a splice.
Old Sep 19, 2002 | 01:15 PM
mraudio13's Avatar
ok i went throught the wires and found out pin b12 was empty. For some reason i moved it . move the wire and BAM it works great. Thanks alot for the quick responses.
Matt
Mraudio@aol.com
Old Sep 19, 2002 | 01:48 PM
Mikey3000's Avatar
Matt
Mraudio@aol.com
you fixed it?
Old Sep 19, 2002 | 03:04 PM
mraudio13's Avatar
Default Re: code 4 crank angle sensor???????????????????? (Salvatore Leone)
yes i fixed it. and it is fast. although i think my head gasket is leaking . I found some oil around the base of the head and there is a little bit of oil in my radiator when i drain it. So i guess i will be ripping of the head this weekend.
matt
Old Sep 19, 2002 | 05:34 PM
Mikey3000's Avatar
i don't get a thank you? w/o me u wouldn't have figured it out.
471r
Feb 18, 2015 12:43 PM
Crazed-Sol
Mar 12, 2013 08:54 PM
h22acd5
Jan 21, 2009 07:32 AM
90h22acrx
Oct 8, 2004 07:58 PM
milruner
Dec 14, 2003 06:48 PM
