power steering
when you do a gsr swap into a civic 98 how do you hook up the power steering feed line. the line the bolts onto the top of the pump. do you need to buy a gsr power steering line or can you use your stock civic pump?.
have you tried using the civic pump with the civic bracket and hooking up the line that way?
You might need to purchase a GSR power steering up since I don't believe it will quite reach the new PS pump on the gsr motor.
you have to use the B series pump, bracket and high pressure line. You'll have to get a hydraulic shop to couple the b-series high pressure line to your Civic line. Look in the yellow pages for companies that work on tractors and construction equipment.
Mainsubject
14
May 4, 2013 03:34 PM
mister_ej2
Apr 5, 2008 06:17 PM
boostincoupe
Jan 23, 2007 01:15 PM
hondacivic2nv
15
Nov 28, 2006 09:21 AM
