vtec oil pressure switch
Old Sep 23, 2002 | 05:05 PM
Snail Tuning's Avatar
Default vtec oil pressure switch
is their a way to check the vtec oil pressure switch? my ecu keeps showing code 22 and can;t figure out whats wronge. i think the switch might be bad. is their a way to check it?
thanks this forum is great its helped me alot with my swap
still no answers to my clutch problem
Old Sep 29, 2002 | 04:32 AM
ben_vtec's Avatar
New User
Default Re: vtec oil pressure switch (bmcc72)
try starting your car and putting a multimeter accross the two connections on the sensor, my guess is that it should be a short circuit, ie < 1ohm.
if youre still having problems, try chopping the two wires that go to the sensor (leaving enough wire to re-join them when required) and just joining them together, if this worksyou know youre wiring is ok, and its a problem with the sensor or oil pressure
Old Sep 29, 2002 | 02:24 PM
B16CRXhybrid's Avatar
Check the ground
Old Oct 21, 2004 | 08:16 PM
brent_G's Avatar
Default Re: vtec oil pressure switch (B16CRXhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXhybrid &raquo;</TD></TR><TR><TD CLASS="quote">Check the ground</TD></TR></TABLE>
Yeah check that...
my problem was the pin at the ecu. it was halfway fallin out.
Dave Brabant
Mar 15, 2018 11:26 PM
si90rex
Honda Civic (2001 - 2005)
Jun 20, 2014 06:57 PM
-Bionic-
Sep 2, 2006 04:50 PM
drudy
Aug 26, 2005 12:20 PM
shonnys92si
Jan 20, 2003 11:45 PM
