ITR guage cluster into '93 GSR-do wires fit?
I want to put an ITR cluster into my '93 GSR. Does anyone know if the wire connectors on the back of the cluster will match? Which other connectors will fit into the back of the ITR cluster such as maybe G3 GSR, civic si...?
Thanks
Thanks
Re: ITR guage cluster into '93 GSR-do wires fit? (LS-Rt)
I have a GSR cluster in my coupe, you have to switch around 15 wires or so, not to hard, you'll also have to modify either the cluster itself or the plastic surround on the dash. Pretty easy install if you're good with a dremel and a soldering iron.
I've never compared the 90-93 cluster to the 94+ cluster. I know that the plugs are different. If you can make it fit and get the plugs for the newer cluster, then a little rewiring and it should work with no problem. I had a 96 GSR cluster in my 92 VX but I changed it back to stock because of the fitment issues. it looked good (other than fitment) and I had it wired up to where everything worked properly.
