DC2 - Civic Suspension Question
New User
I have a GSR that was wrecked and I plan on swapping it into an EG hatch. I know I need to replace the rear LCAs in order to use the GSR shocks/swaybar but do I need to replace the UCAs and the trailing arms as well in order to use the GSR rear brakes?
TIA!
TIA!
Re: DC2 - Civic Suspension Question (Drew M)
ya, you will need those in order to do rear discs. I don't believe the rear discs will work with the stock civic ones, but GS-R's you should have no problem with the install
New User
Re: DC2 - Civic Suspension Question (fowler)
I have to take it apart though. Here is why - I had a GSR. It hit a tree and bent All 4 of my control arms and both of my trailing arms but the brakes/hubs are fine. I don't want to buy an entire brake swap because I don't need it. I was just curious if I needed to replace the trailing arms in order to run the GSR brakes I already have. I know I need to change the LCAs to run the GSR shocks etc.
Are the UCAs the same between a DC2 and an EG?
edo3276
06-17-2004 05:56 PM
Jdm93civic
11-25-2003 05:16 AM
SoloSol
03-04-2002 02:51 PM
