Knock Sensor
Old Sep 19, 2002 | 08:13 AM
kuelerz's Avatar
Default Knock Sensor
so i was taking the engine wiring harness of of my JDM B18C last night and the knock senser decentigrated in the harness becuase it was so brittle.
i am going to be running a p72 ecu and was wondering if anyone knew a way to by pass the sensor or were i can get one for cheap.
Old Sep 19, 2002 | 09:32 AM
Grimm's Avatar
Default Re: Knock Sensor (kuelerz)
check the classifieds i thought i saw one in there... with some other stuff...
i duno about bypass... Mine has a faulty wire so I got a cel...
Old Sep 19, 2002 | 09:56 AM
Katman's Avatar
wait a sec..
did the sensor itself fall apart or did the plug that clips onto the actual knock sensor fall apart?
Old Sep 19, 2002 | 10:10 AM
-Whitey-'s Avatar
Default Re: Knock Sensor (Katman)
same excact thing happend to me on my b16a i took the harness off and pulled the plastic piece of the sensor away from the metal piece that bolts to the block!
they are about 100-170 bucks to buy new!
Old Sep 19, 2002 | 11:20 AM
Tofurky's Avatar
how are you guys even using your jdm harnesses?
at first we tried that with ours, but after about an hour of realizing we can't just "bring one side to the other" we plugged in our cx harness.
Old Sep 19, 2002 | 12:45 PM
Katman's Avatar
Default Re: Knock Sensor (Ruckus138)
hey ruckus, by chance, are you doing a GSR swap (bought from JHP) in your car, with the help of Dave Schulz (slidesquad) ?
Old Sep 19, 2002 | 01:47 PM
kuelerz's Avatar
i am not using the JDM harness just the plugs off of the harness. the sensor its self fell apart not the plug
Old Sep 19, 2002 | 07:20 PM
Westrock2000's Avatar
Doesn't the B20B have a knock sensor on it? If so, I won't be needing mine since I'm staying Non-Vtec. Tell me where it might be and I can sell you one.
Old Sep 19, 2002 | 07:47 PM
Tofurky's Avatar
yeah. it turns out they gave me 2 bad distributors.. oh well i guess that stuff happens a lot.
it stinks that it took two and a half weeks to figure that one out. dave was losing his mind.
it's sooo close to actually moving now. just needs some "clutch juice" as i like to call it.(dave would make fun of me so much for saying that.)
would you recommend that i just purchase an ex/gsr wiring harness, or is it possible to wire the o2 sensor using stuff of the gsr harness with the cx harness?
i understand dave called you a bajillion times. hehe, sorry bout that. but we were seriously monkeys scratching our heads when it wouldn't start for the first 2 weeks. but thanks for all the help. and thank jebus dave was there, who knows what i would've ended up accidently doing.
here's some install pics...
https://honda-tech.com/zerothread?id=280954
Old Sep 19, 2002 | 09:26 PM
Katman's Avatar
*** ahhh...hah i had a feeling it was you DSS was helpin out ..hehe. so it was just the distributor then eh?
***** lol yah he would! haha..
*** i personally despise wiring and would take the easier route....GO EX/Si engine harness.
***heh no prob.
bustah49
May 11, 2007 07:57 AM
FFerio
Aug 13, 2005 10:36 AM
lsvtec2000SI
Mar 14, 2005 12:32 PM
CrazyHB
Aug 30, 2004 12:15 PM
