ECU Codes
Old Sep 30, 2002 | 04:46 PM
westcoaststyle's Avatar
Default ECU Codes
Ok, here's what I've got going:
Fully built B18C1 in my '95 Civic DX. I just got the thing running a week ago and have been fixing minor mechanical problems and I'm done with all of that now. What I need to do now is figure out what's up with the ECU and the CELs I'm getting.
I jumped the system and when I went to count for the code, my Check Engine light flashes the long flash constantly, while the SRS light gives me the codes. The SRS light is flashing a 51, 92, and 21. I checked out on http://www.jdmfan.com and there is no listing for a 51... also, I bought an OBD1 ECU (P72), OBD1 distributor and OBD1 harness.
Someone mentioned to me that my ECU could be stuck in a diagnostic mode... I reset the ECU a couple of times, but I still get the same codes. Anyone have any ideas??? I'd really like to get this thing running properly!
Thanks!!!
Old Sep 30, 2002 | 06:57 PM
Jared's Avatar
Default Re: ECU Codes (westcoaststyle)
Is it possible that the SRS light is flashing SRS codes and the MIL is just giving you a code 10(iat)?
Old Sep 30, 2002 | 07:19 PM
Default Re: ECU Codes (Jared)
GOOD CALL! I didn't know that there were SRS light codes.... so if that's the case, what is an SRS code 51, 92 and 21?
Old Oct 1, 2002 | 12:55 PM
Got it fixed! My IAT sensor was bad. I had a friend with an '01 GSR come over and I used his.. the CEL went away!
Does anyone know if the IAT sensor from a D15B7 will work correctly on a B18C1? I took the one off my blown DX motor and put it in the place of my bad IAT, I don't get another CEL, but I don't know if the sensor will work correctly with the B18C1? Anyone??
Thanks!!!
lgoodgrace
Apr 27, 2015 03:35 PM
z6hatchboy
Sep 16, 2010 04:16 PM
jonathan13
Aug 24, 2010 11:19 AM
jfields06
Dec 27, 2008 06:42 AM
frostt3ch
10
Jun 22, 2003 11:09 AM
