Ok guys have i coverd all the bases??
Well the mighty d15 finally died in my 95 civic dx, and was pulled today , So i am swaping a 96 LS
I am getting...
96 1.8l ls engine
96 ls manual trans
93 teg driver/pass. half shalfs
p72 ecu
96 shift linkage
is that all?? And is there a how to cause i know there are a couple wires i have to run? If someone has already done this and would like to give some TIPS any would be a great help THANKS guys
I am getting...
96 1.8l ls engine
96 ls manual trans
p72 ecu
96 shift linkage
Re: Ok guys have i coverd all the bases?? (twitchm80)
hmm... don't know cause the i found were 93 and they were cheaper, btw why does it matter if i have ABS or not... cause i don't?
Btw thanks for the input letride!! maybe i will go with the 96's then
[Modified by twitchm80, 2:32 AM 9/30/2002]
Re: Ok guys have i coverd all the bases?? (letsride)
thats what i thought but i called a shop and they said that it did matter and that was why they told me to go with the 93 axles cause they were not-abs... i wish shops knew what they were talking about THanks for the info
So letsride are you saying that i have everything? because experience speaks and this is my first swap!
Yea you've got the bases covered. Remember ... Fluids, ney timing belt, water pump, cap rotor, plugs, fuel filter etc. Just take your time.......
Rever21
05-03-2017 01:49 PM
ecks_fourttwo
03-17-2005 06:09 PM
