G2 integra -> G3 integra parts swap
Gonna possibly convert an automatic G3 to Manual ... i have a 1992 G2 5 speed .... the pedals.. pedal assembly ... and shift linkage ect .. should all line up right ? the 92 ECU work fine as well in the 1995 G3?
Re: G2 integra -> G3 integra parts swap (zilverz)
Use the ECU that goes with the engine you're using. The shift linkage and change rod shouldn't be a problem, at the most you'll have to drill some holes to mount it to the car. I'm really not sure about the pedal assembly. If it doesn't bolt up you'll have a problem, because the pedal assembly for the G3 is for a hydro tranny, and you need to attach a clutch cable to the pedal.
Re: G2 integra -> G3 integra parts swap (Brian_92GSR)
Hmmm ive been told that the 92->95 civic pedals/assembly would bolt right in to the 95 integra .... hmmm think this 92 integra is all that different ?
Anyone else know of anyone robbing manual conversion parts from a G2 integra ?
HondaMechanic24
12-14-2012 12:42 PM
bap168
09-16-2007 06:33 AM
