CTR pistons in a B16a?
Old Oct 1, 2002 | 02:38 AM
enhancedCL9's Avatar
Default CTR pistons in a B16a?
Has anyone here done this set-up before? and how is it?
Old Oct 1, 2002 | 10:22 AM
PhatOptimo's Avatar
Default Re: CTR pistons in a B16a? (thizguy)
They are great! I am still working on my setup. I have run the CTR pistons in my B16a for about 6 months. I have recently had the valve seals replaced and also got a valve job. Working on putting it back together.
Old Oct 1, 2002 | 10:31 AM
-Whitey-'s Avatar
Default Re: CTR pistons in a B16a? (Phat_Optimo)
i too am pondering this poor mans ctr motor please make a thread with a good review about the set up and what you think telling us other guys iof iys worth it
Old Oct 1, 2002 | 11:41 AM
Default Re: CTR pistons in a B16a? (one_honda)
Yeah, That would be nice if we can get aLL the info we can!
Old Oct 4, 2002 | 02:59 AM
ANYONE???
Old Oct 4, 2002 | 03:58 AM
Davep's Avatar
Default Re: CTR pistons in a B16a? (One Honda)
Well it won't excatly be a ctr, more like a b16a with ~11:1 CR.
Old Oct 5, 2002 | 10:34 PM
3rdGteg's Avatar
Default Re: CTR pistons in a B16a? (Davep)
more like only 10.8:1 -- unless you slap a gsr head on top of that ctr pistons equipped b16a block, then it'll come up to 11:1 CR.
Old Oct 6, 2002 | 03:39 PM
uglyhybridcrx's Avatar
Default Re: CTR pistons in a B16a? (3rdGteg)
one of my co-workers did a poor mans ctr swap into a CRX, pistons, cams, valve springs, retainers, and a block guard. he loves it, pulls 160 to the wheels, and revs to 9500 all day. the guy is kind of a nut, but no problems so far!
Old Oct 6, 2002 | 08:23 PM
3rdGteg's Avatar
Default Re: CTR pistons in a B16a? (uglyhybridcrx)
Why rev so high? Does he feel any pull after 8500?
Old Oct 6, 2002 | 09:12 PM
MisterB's Avatar
i am building a b16 with os ctr pistons, cams, valve train... everyone i have talked to about it has said nothing but good things except im in cali with 91 octane so on really hot days i will retard the timing a few degrees
Old Oct 6, 2002 | 10:40 PM
Default Re: CTR pistons in a B16a? (cl4show)
What is the differents between The startard or .25 overbore pistons?
Which one is rec. or better?
Old Oct 7, 2002 | 09:07 AM
MisterB's Avatar
the difference is that the .25 over is a bigger piston .25mm converts to 10 thousanths over, so the cylinder wall will have to be bore out. the bigger piston give slightly more compression and also increases your displacement. when rebuilding a motor i alway get oversized pistons so i know that the cylinder is clean and true... especially on a block that is old or abused or high millage
Old Oct 7, 2002 | 02:42 PM
3rdGteg's Avatar
But remember, you can only rebore so much due to the thickness of the b16 cylinder walls. Only about 1mm over standard and the block's gonna have to be resleeved or trashed; So I wouldn't rebore unless the cylinders need it.
Old Oct 7, 2002 | 03:11 PM
MisterB's Avatar
Good point
i dont know if going that much ~40 thou over is safe but 10 thou over is ok for NA
yes good idea, im going over cuz i never plan on doing it again if some thing does happen ill just through the block away and start all over.
also remember that the ctr pistons will not just bolt on the the b16a rods, 1mm will have to be shaved off each side of every rod
Old Oct 7, 2002 | 04:11 PM
RuKKus's Avatar
what kind of compression will i get with LS block, CTR pistons and B16 head??
Old Oct 7, 2002 | 04:20 PM
MisterB's Avatar
Default Re: CTR pistons in a B16a? (RuKKus)
about 12.3
go here
http://www.c-speedracing.com/howto/c.../compcalc.html
Old Oct 7, 2002 | 08:24 PM
skud_dusty's Avatar
i had a first gen b16, ctr pistons, and an obd1 gsr head in my cx hatchie...lets just say it screamed, and i could feel vtec pull HARD in 3rd gear (mad 3rd gear vtech yo!)
Old Oct 8, 2002 | 12:18 AM
Default Re: CTR pistons in a B16a? (skud_dusty)
So this set-up Should be aLot faster then a pLan oL b16a?
Old Oct 8, 2002 | 11:31 AM
MisterB's Avatar
Default Re: CTR pistons in a B16a? (SLOW CRX)
yes, faster but depends on your definition of alot
egchan
Feb 27, 2003 12:30 PM
MikeMAN
Oct 17, 2002 11:39 PM
qbsi
Jul 19, 2002 07:43 AM
