h22a idle
Old Oct 3, 2002 | 04:55 AM
M1kevtec's Avatar
New User
Default h22a idle
every once in a while my car idles weird. It's revving up and down but not erratically. Its very mild and could be stopped when you step on the gas lightly.
It just started doing it about a when temp got below 50 degress F ---
Does anyone have a solution for this problem? ANy common fix you might know?
Thanks
Old Oct 3, 2002 | 07:27 AM
2point6's Avatar
Default Re: h22a idle (M1kevtec)
Reset the EACV and this should take care of it. Get a helms manual to help you through the steps. It is easy however.
Old Oct 3, 2002 | 09:05 AM
poison's Avatar
Thanks
I hear that. I keep thinking it's a small vacuum leak or not enough coolant problem, but could be wrong
I'm havin the same prob though
Old Oct 3, 2002 | 10:16 AM
Newman's Avatar
New User
Purge the coolant. Just had that problem last week.... purged it and it idles smooth again.
Old Oct 3, 2002 | 12:33 PM
poison's Avatar
Default Re: h22a idle (Newman)
don't mean to sound like a dumbass.......you say purging it you mean to completely flush it and get the crap out of it? err.....
Old Oct 4, 2002 | 05:05 AM
cccya's Avatar
Default Re: h22a idle (poison)
no just open the bleeder screw on top of the themastat housing. (where the coolent goes in from the rad.) just crack it open just enough coolant will leak out. and should take care of any air in the system. have your car running when you do this. HTH
calinomad
Oct 1, 2006 04:41 PM
duceducecord
Sep 4, 2006 01:04 PM
H23AHybridEG
14
Nov 3, 2004 03:38 PM
tylek17
Jan 29, 2004 08:12 PM
