o2 senser help
when you use an obd 1 motor, b18c or b16a, in a obd II car, 96+ civic, with a skunk 2 conversion harness, what o2 wires do you use? do you wire up the primary plug in on the harness to fit for the primary o2 or do you use the secondary plug in to fit on the o2 senser?
Obd II or Obd I ECU
if the ECU is Obd I you don't need the second o2 wired at all it is only emissions. the primary must stay wired as that adjusts your fuel/air mixture.
If it is an Obd II ecu i think you will have more problem than just the o2 not sure about that though......
[Modified by LegoZ81, 4:32 PM 10/1/2002]
does anyone know how to wire the primary o2 on a 98 civic. i looked and the wires are orange, yellow, white and black but the wires on the sensor are green, white, black and another color.
help me please
help me please
outlawteamteg
Apr 11, 2007 06:45 AM
