No reverse
my h22a won't go to reverse for some reason--- i tried everything and still wont---when it does---it seems like its not catching---can anyone help me.
what could be wrong with it? My fifth gear also grinds every once in a while---could it be the cable?
its in a 92 cx hatch by the way
please any suggestions?
Do you have a aftermarket shifter? Try that, if not look at the cable might be binding. Are you hard on the trans. The fluid in your trans is 10-40 motor oil? Lot of times people put gear oil. Last and worst case scenario, you have a bad syncro. Which will relate 5th and R. Syncro will usually affect two gears.
[Modified by RWDdrifter, 5:05 PM 10/6/2002]
[Modified by RWDdrifter, 5:06 PM 10/6/2002]
lancemah
10
Aug 14, 2013 05:46 PM
