Help needed for a B18A swap into a 2000 Civic hatch
I need to know what motor mounts do I have to use when installing a B18A into a 2000 Civic hatch? I know that I have to get the AC bracket and the rear mount bracket from a 99-00 Civic Si but what about the rest of the mounts? I have at my disposal the mounts that came in my EK and all the mounts from the 93 Integra. Thanks.
Re: Help needed for a B18A swap into a 2000 Civic hatch (Yusuke)
this is for a b16a into a 96 but im almost certain its the sameParts list for EG6 B16A engine, ECU, and Y21 tranny, into '96 Civic EX coupe:
Del Sol VTEC '94 & up:
Intermediate shaft
'A' pipe(with new gaskets for engine side and cat side and new mounting nuts and studs if needed)
A/C bracket-mount
A/C belt
Alternator belt(if alt. pulley has same width belt)
Axle nuts(Integra same)
Axle spring clips(Integra same)
Axle seals(fit into tranny openings)
Upper and Lower radiator hoses
'94 & up Integra:
Axles
Shift linkage(with shifter lever)
front right tranny mount
rear main tranny mount-must be GSR(modified to Matt Blodgett's instructions or use a '99 Civic Si's)
'92-'93 GSR
P/S pump(if crank pulley has V belt pulley for it like mine)
P/S bracket
P/S belt
OEM '96 Civic EX
P/S pump high pressure line(modified to fit new pump)
Fuel line from filter(turned backwards with 1 tab bent back
Throttle cable(and need to make a mounting surface for the cable holder)
Alternator(had to extend engine's bracket)
Main wiring harness connector(big green plug near ecu)
Main wiring harness connector(under hood, left strut tower)
Other
Belt to fit if using Civic alternator
Wire to extend/relocate JDM wiring harness
Shielded wire for same reason(24 gauge 4 wire from Radio Shack works fine)
[Modified by vtec69, 12:12 PM 10/3/2002]
Intermediate shaft
A/C bracket-mount
A/C belt
'94 & up Integra:
Axles
'92-'93 GSR
P/S bracket
P/S belt
OEM '96 Civic EX
Other
ApexiChild
11-29-2004 02:13 PM
Nikos
06-19-2003 08:51 AM
