Wiring Harness???
Old Oct 2, 2002 | 08:46 AM
dropcivc's Avatar
Default Wiring Harness???
ok....this may be a stupid question. I swapped a 2000 b16A2 into my ek hatch. I know that i used my sock cx harness, cause the plugs for si aren't the same? my buddy is swapping in a 2001 gsr into his EK. can we use the gsr harness? or do we have to use his cx harness? Any help...
dropcivc
Old Oct 2, 2002 | 10:44 AM
hondaZvic's Avatar
Default Re: Wiring Harness??? (dropcivc)
the gsr harness may work, i dunno, but the rule is to use the harness that came with the car, and adapt it to fit the engine. that way there is no problem hooking up the interior switches.....
Old Oct 2, 2002 | 01:38 PM
dropcivc's Avatar
Default Re: Wiring Harness??? (hondaZvic)
yea.....good point. I just needed someone to put it like that. Thanks
dropcivc
Old Oct 2, 2002 | 01:59 PM
poison's Avatar
man you are just tearin it up huh?
Old Oct 2, 2002 | 11:53 PM
hondaZvic's Avatar
Default Re: Wiring Harness??? (poison)
ahhaha.. i gesss so.. doin my own swap.. i feel like i know it all now.. i cant wait to get another car, and do another swap.. i bet i could do another h22 in a weekend.. compared to 4 months... sheesh!!!!!!
Old Oct 3, 2002 | 04:48 AM
Trey's Avatar
25 Year Member
You CAN NOT use a DC/ EG harness in an EK chassis.
The EK uses a one piece harness, the others use a two piece harness.
CX harness will do with extra wiring.
check out http://www.jspectuning.com/6gen for help........
Old Oct 3, 2002 | 07:22 AM
pennies_hatchie's Avatar
Default Re: Wiring Harness??? (Trey)
well i dont know if this helps, but i had to use my si (eg) wire harness for my b16a (j-spec).....good luck
Old Oct 3, 2002 | 09:18 AM
mts20k97's Avatar
I dont if this will help. I swapped a 98 gsr into my 97 hatch last weekend. I had to move the wire from A14 to A12. It's the blk/blu wire for the IAC valve.
Old Oct 3, 2002 | 09:48 AM
poison's Avatar
i bet you i can do another h22 swap in 2 days rather than the 3 days it took me hehe
Old Oct 3, 2002 | 10:04 AM
hondaZvic's Avatar
3 days?!!?!?! running too? i had the motor in in a half a day, that was the easy part.. but then i got the wiring all messed up.. and had to straighten myself out.. didnt know what i was doing.. ***learned a $hitload*** then 4 months later... finally
coupatroopa
Nov 2, 2010 06:26 PM
import-tooner
Apr 12, 2009 04:41 PM
HarosGSRek
17
Mar 29, 2009 10:37 AM
562daybid
Mar 23, 2008 06:29 PM
