6th gen EX vs HX wiring harness question
I can't find a 96-98 EX wiring harness in a junkyard and $450 for a new one is a little steep. I can get a 97 HX wiring harness at a decent price. How much different are the harness'?
Re: 6th gen EX vs HX wiring harness question (Bezerker)
just use your stock one. Even the EX harness needs extensive work legthining plugs etc, so an EX harness only saves you 3 wires worth of work.
Oh yeah, and an HX harness should work as well, but will still require work to be adapted to a B series motor.
Re: 6th gen EX vs HX wiring harness question (tonyxcom)
Thanks for the information.
The only difference between the EX wiring harness and the HX is the 4 wire o2 sensor, that is it.
EX has a 4 wire o2 sensor already, when the HX has a 1 wire o2 sensor.
BigRonDawg
04-25-2006 09:37 AM
