zc problems please help
Old Sep 25, 2002 | 09:35 PM
zcrx1's Avatar
Default zc problems please help
i just swapped in a zc engine into my crx 6 days ago anyhow the problem is that when ever the car is on ilde it revs up and down by itself. it also effects my driving only at low rpms. it makes the car jerk forward and backwards when i drive from 1500 rpm to 3000 rpm. but when i go past 3000 rpm the car accelarates good. please help!!!
Old Sep 26, 2002 | 09:42 AM
enhancedCL9's Avatar
Default Re: zc problems please help (zcrx1)
Check your coolant! Air bubbles in the coolant cause it to idle funny-up and down. Just bleed your coolant and it should be fine. i had the same problem after my swap.
Old Sep 26, 2002 | 01:34 PM
11secdx's Avatar
make sure the vacuum line is on the FPR.
Old Sep 26, 2002 | 04:05 PM
boostinb18's Avatar
Default Re: zc problems please help (11secdx)
mine did the same thing......just adjust your idle......and check your vacuum lines, i gaurantee it has nothing to do with your coolant!
Old Sep 26, 2002 | 11:02 PM
zcrx1's Avatar
can anybody show me the proper diagram for vacuum hoses for my crx dx with a zc egine installed??? please help
D7_62
Classic Hondas
Mar 8, 2012 08:47 PM
CRXguy_88
Sep 23, 2010 06:11 AM
ryyo
Feb 24, 2007 11:11 PM
tUNERiNSIDE03
May 21, 2003 09:05 PM
zcrx1
12
Sep 26, 2002 11:02 PM
