ef h22 engine conversion
Old Oct 4, 2002 | 08:24 PM
epren's Avatar
Default ef h22 engine conversion
Which axles will i need to use, same as an EG h22 conversion?
What other problems will i encounter with this type of conversion?
thanks
Old Oct 4, 2002 | 08:42 PM
Qfactor's Avatar
Default Re: ef h22 engine conversion (epren)
you will need to do some cutting and welding. custom fabrication engine mounts and front crossmember cable to hydro conversion. wiring fabrication. and few more things here and there.
Old Oct 5, 2002 | 12:04 AM
TrAnCeD_RaCeR's Avatar
Default Re: ef h22 engine conversion (Qfactor)
do you have the h22/h23 conversion stock or with other goodies to cut that time? what hood are you using?
Old Oct 6, 2002 | 10:05 PM
KS-R's Avatar
Yup.. eactly what he said.. and just to at to that.. patience and a good set of wiring diagrams
Old Oct 7, 2002 | 12:54 AM
epren's Avatar
Default Re: ef h22 engine conversion (KS-R)
from the times you guys are posting
its a pretty good conversion to hit 12s .
is it worth doing than a b series conversion
considering money and time??
92CivicEG3
Feb 9, 2012 01:57 AM
95dcsleeper
Jul 22, 2005 09:25 AM
95dcsleeper
Jul 22, 2005 09:24 AM
95dcsleeper
Jul 22, 2005 12:06 AM
jrarinas13
Sep 20, 2002 08:51 PM
