LS Vtec
Old Sep 26, 2002 | 07:05 AM
Quiz's Avatar
Default LS Vtec
If this has been beaten to death I'm sorry did a search and ls vtec all over the place but not very specific.
I have a Integra GS (93) with a B18A. Would like to swap the head for a B16 Vtec. A few books I read had little info. So far all ive gatherd is I need the B16 ecu, head intake manifold, thottle body, feed the vtec syloniod, and small wiring. Looking for more info/confirmations that the gernal publications may overlook. Any under-hood clearence issues. will I have to swap any pullies. I'm assuming I'll have to use the B16 timing belt. Any modification to the head like oil or coolent passeges that need to be blocked off. Any exhaust/intake routeing problems?
Old Sep 26, 2002 | 07:34 AM
Jeff C's Avatar
Default Re: LS Vtec (Quiz)
have you read this yet...
http://www.c-speedracing.com/howto/lsvtec/lsvtec.html
-no clearence issues
-no pulley swapping
-relocate dowel pins
-run vtec oil supply line to head and block existing passage in head http://www.c-speedracing.com/frame.html "LS/B20-VTEC hardware kit"
-run pcv system http://www.theoldone.com/components/breather/
-upgrade to gsr water pump, timing belt and oil pump
-new ls (b18a) head gasket
-chipped p28 ecu and run wires for vtec switch and vtec pressure switch
i think thats the basics. i will get corrected if i missed something.
Old Sep 26, 2002 | 08:04 AM
Quiz's Avatar
Default Re: LS Vtec (Jeff C)
That is the information I was searching for. That page is now logged to a file for future reference. Thanks. Also looking for books on Honda's in general. N/A, FI, anything on modifying. Any recomendations.
[Modified by Quiz, 12:07 PM 9/26/2002]
Old Sep 26, 2002 | 09:55 AM
vtec69's Avatar
c-speed.com has some stuff on n/a tuning
Old Sep 26, 2002 | 12:20 PM
X2BOARD's Avatar
Default Re: LS Vtec (vtec69)
Here's some threads:
https://honda-tech.com/zerothread?id=287228
https://honda-tech.com/zerothread?id=287130
https://honda-tech.com/zerothread?id=263598
https://honda-tech.com/zerothread?id=278318
https://honda-tech.com/zerothread?id=278458
https://honda-tech.com/zerothread?id=275385
Also search the archives with every possible variation... LSVtec, LS/Vtec, B20/vtec, CR/Vtec, and my personal, LSVT....etc...
HTH
X2
Old Sep 26, 2002 | 05:47 PM
Snail Tuning's Avatar
http://www.fifthgearonline.com/tech/...s/bseries3.htm
frankenstine honda engines
Jul 25, 2006 09:41 PM
98IntegraLSNonVtec
60
Feb 28, 2006 04:46 PM
turbotime
Jan 12, 2006 04:12 PM
dohcivicls
Jul 29, 2005 02:21 PM
Steve-o
Jan 29, 2003 11:45 AM
