wiring secondaries
Old Oct 4, 2002 | 08:34 AM
kuelerz's Avatar
Default wiring secondaries
on a gsr i know i need to wire the secondaries but the when i looked up the wiring on hybridgarage.com they only say to hook up one wire, pink/blue, to A17, does the second wire just go to a ground on the block or to a ground on the ecu?,
also what is an EVAP purge valve? and where is it located?
Old Oct 4, 2002 | 09:18 AM
M1kevtec's Avatar
New User
Default Re: wiring secondaries (kuelerz)
that will go to ecu ground---you could tap that from the driver's side engine harness--yello/black---same ones going to your injectors.
Old Oct 4, 2002 | 09:45 AM
Malachi's Avatar
if its an obdI engine, ground it. if its obdII then to a 12+v switched source. dont worry about the evap thing, its for emissions. if you really want it to work splice the wire going into a17 so it goes to a20 also.
Old Oct 4, 2002 | 10:38 AM
kuelerz's Avatar
Default Re: wiring secondaries (Malachi)
if the EVAP isn't wired will i get aa check engine light?
eg6madness
Nov 17, 2007 04:46 PM
Mikes2000civicsi
Oct 24, 2007 06:30 PM
1sikhatch
Nov 27, 2006 01:40 AM
Hyaboosta
Jan 11, 2005 05:48 PM
Sketch_hs
Aug 19, 2004 08:44 AM
