Parts list for b16a2 into 97 dx hb (verification per hybridgarage)
Old 09-27-2002, 07:04 AM
Ehron's Avatar
Default Parts list for b16a2 into 97 dx hb (verification per hybridgarage)
Plus I need a 99-00 > 96-98 obd2 conversion harness. I have to pass emissions so OBD1 is not an option.
I have the a/c compressor on the b16a2 so I do not need to get a new one. I am guessing the belts from the 2 engines are not the same? Do I need new accessory belts? I will not be converting to power steering.
I am going to buy a 99-00 si rear mount, and ac mount. I can reuse all other mounts?
In the manual it says to replace a ton of washers. Do I need to order these from Honda as well? OR do I just go buy appropriate metric washers?
I guess I am going to be draining pretty much all the fluids before the swap? Any suggestions on what to replace them with (obviously the corresponding fluid )? I guess the question is do I need aftermarket stuff, or if need is the incorrect term whether I will see any benefit from using upgraded tranny oil or similar.
Also as long as the linkage is out of the car I would like to get a short shifter. Any suggestions on brands?
Wish me luck. Luckily I will be traveling a lot from Monday-Friday so if anything catostrophic happens I only have to bum rides 2 days a week
I appreciate your input.
[Modified by Ehron, 4:06 PM 9/27/2002]
[Modified by Ehron, 4:11 PM 9/27/2002]
[Modified by Ehron, 4:12 PM 9/27/2002]
[Modified by Ehron, 4:18 PM 9/27/2002]
[Modified by Ehron, 5:48 PM 9/27/2002]
Old 09-27-2002, 08:50 AM
poison's Avatar
Default Re: Parts list for b16a2 into 97 dx hb (Ehron)
everything looks good from my book.
good luck bro. shouldn't take you more than 2 total days for the swap
Old 09-28-2002, 08:54 AM
dropcivc's Avatar
i am confused. Are those lists all things that you need from those cars in order to put a b16a2 into your 97 hatch. i have a 97 hatch with a 2000 b16a2 in it, and I didn't need half of that stuff. I passed emissions no problem.
dropcivc
Old 09-28-2002, 10:09 AM
Ehron's Avatar
Default Re: Parts list for b16a2 into 97 dx hb (dropcivc)
What did you do about your ecu? I know some of that stuff pertains to a del sol vtec b16a3. So do I need new washers from Honda? Did you replace all of yours? Thanks.
Old 09-28-2002, 07:27 PM
vtec69's Avatar
good luck
kboy82
06-23-2005 10:12 AM
speedehatch
09-21-2004 06:31 AM
scivicex99
06-20-2004 08:25 PM
Hatchdude
03-02-2004 06:30 PM
Ehron
01-04-2003 04:57 AM
Quick Reply: Parts list for b16a2 into 97 dx hb (verification per hybridgarage)
