D16z6 wiring - HELP... QUICK!
Old Oct 2, 2002 | 05:29 AM
sparq's Avatar
Default D16z6 wiring - HELP... QUICK!
Hey guys, I should have a D16z6 here Sat/Sun and I was wondering a few things. Can anyone point me to some wiring help - I will have the ECU but my DX isnt wired for VTEC correct? So I will need to run some wires... but, which? Thanks - need to get this "temporary" motor running to get my car back on the road and chuggin along
Old Oct 2, 2002 | 06:41 AM
SuperCivic's Avatar
Default Re: D16z6 wiring - HELP... QUICK! (sparq)
which car are you putting this motor in? the 92 hatchbacks come prewired for vtec. if you have a 88-91 dx then it's a bit more complicated. if have a 92-95 it's not hard..hybrid.honda-perf.org should have the right charts.
Old Oct 2, 2002 | 01:00 PM
sparq's Avatar
Default Re: D16z6 wiring - HELP... QUICK! (SuperCivic)
I have a 92 DX sedan (stop laughing )
Also, I cant find crap since they changed the website design
Old Oct 2, 2002 | 01:08 PM
l0p3z's Avatar
this link brings you to their old design: http://hybrid2.honda-perf.org/
but all i can find is dx for the 4G civic. i don't know if its the same, but i doubt it.
Old Oct 2, 2002 | 01:17 PM
poison's Avatar
92 DX Sedan is not bad
Ferio's are nice heh.
for wiring of VTEC, I would just hard wire it from the ECU to the vtec solenoid valve and the oil pressure sensor.
VTEC Solenoid valve has 1 wire and goes to A4
VTEC Oil Pressure Sensor -> the blue/black wire goes to D6 and the other wire is body grounded.
here is the pin-out diagram so you know where the wires go looking at the ECU connectors:
hth
Old Oct 2, 2002 | 01:31 PM
fixhondas's Avatar
IF the Z6 has a harness with it, all you have to do is plug it in. The 92 models have VTEC wires up to the passenger shock tower where the engine harness plugs in.
sparq's Avatar
Default Re: D16z6 wiring - HELP... QUICK! (poison)
Thanks man, helps a TON!
What do I use for the pins though... where can I pick em up?
Old Oct 2, 2002 | 01:45 PM
fixhondas's Avatar
Pins will already be there, as will the wiring.
[Modified by fixhondas, 5:45 PM 10/2/2002]
Old Oct 2, 2002 | 02:05 PM
sparq's Avatar
Default Re: D16z6 wiring - HELP... QUICK! (fixhondas)
So its already wired for VTEC? Should I just run to the garage and pull my plugs and look? LOL - its a long walk, BAH... so all I have to do is just drop in the motor, and plug my harness into the VTEC ECU and its gonna work?
Old Oct 2, 2002 | 02:10 PM
poison's Avatar
Yes correct. 92 Models are already wired for the shock tower, however, if it does not work then you will have to hard wire.
I know the hatches are wired for VTEC, but not sure on the 4 doors, I guess that'll clear it up
Old Oct 2, 2002 | 05:38 PM
fixhondas's Avatar
All 92's should be wired for VTEC- yes.
Old Oct 2, 2002 | 08:10 PM
sparq's Avatar
Alright, I will have the engine harness... and if my sedan is wired for vtec & the shock tower - all I will have to do is plug it in, and swap out the ECU and its all done? The ECU is for an auto... my car is manual.
If I understand correctly the auto ECU's are configured a little differantly as far as how they run. Should I pickup one of those "racing chips" to better map the ECU to run with my car?
Old Oct 3, 2002 | 09:23 AM
poison's Avatar
yes that would work
IA95civicDX
Jul 7, 2005 09:12 AM
mycivicisslow
Jan 27, 2005 03:08 PM
chrystyle
Feb 19, 2004 05:29 PM
