Overheating going uphill on freeway...
Old Oct 2, 2002 | 03:54 PM
Tofurky's Avatar
Default Overheating going uphill on freeway...
It's a 94 gsr motor in a 92 cx. I'm using the cx radiator, and i'm wondering if that's the problem.
Today on the way to school, going uphill on the freeway, the temp. went about 3/4 and was inching it's way to about 4/5.... pulled off the freeway and it came down.
the fan comes on, city driving it's surprisingly cool, no leaks.... the thermostat is working good...
I just changed the coolant, replaced the fan with the fan from my old 01 gsr...
recommendations? i'm going to change the radiator as soon as possible, I was looking into the GSR, but we're installing the turbo in a couple of weeks, so there might be a clearance issue?
Old Oct 2, 2002 | 04:05 PM
letsride's Avatar
Default Re: Overheating going uphill on freeway... (Ruckus138)
Check your timing too!!
Old Oct 2, 2002 | 05:27 PM
poison's Avatar
Default Re: Overheating going uphill on freeway... (letsride)
yes, get a dual core radiator, and check your ignition timing
Old Oct 2, 2002 | 08:15 PM
976's Avatar
976
New User
Default Re: Overheating going uphill on freeway... (poison)
Not enough coolent, when at an angle (uphill) engine doesn't pull enough coolent.
Clough in lines; you might want to "super" flush.
You didn't unscrew bleed screw when filling.
Few things to check for.
hotcivicsi
Feb 25, 2009 05:05 AM
civicmatt
13
Sep 25, 2003 11:40 AM
vw-honda-hatches
15
May 6, 2003 02:51 PM
wreckedagain
Mar 31, 2002 12:49 PM
kento
Jul 16, 2001 05:15 PM
