B16A in EF not getting GAS
New User
I got a problem guys, I installed a B16A in my friends CRX. I cranked it today and it spins over, but it doesn't start like usual. It seems like its not getting any fuel. I double checked everything from wiring to fuel lines, and I still can't find anything that could be causing this. If any got an answer to this I would glady appreciate it.
Thanks
Thanks
Re: B16A in EF not getting GAS (CivicSiR7)
when u turn the key half way, do you hear the fuel pump coming on?
and after starting it do you smell gas?
[Modified by Ruckus138, 8:30 PM 9/28/2002]
Re: B16A in EF not getting GAS (Ruckus138)
if you do smell gas or you do hear the fuel pump turn on...then it's probably the distributor, the coil might be out, try using someone else's distributor
and the connection to the ecu is cool right?
FreddieC
10
01-14-2011 05:02 PM
ATS*Mark
10-26-2004 08:16 AM
