b20z problems help
Old Jun 26, 2005 | 04:54 PM
CTRwannaB's Avatar
Default b20z problems help
the b20z bog badly on WOT?
2x checked all senors
still didn't work
this is with the crv harness ofcourse
i use to have a 94 LS in there with the CX wiring harness and it worked fine.
so i decided to change out the wiring harness into the CX one again hoping that would help....it did but not much it only idles better now :/
i then replaced the intake manifold with the 94 ls one
end note: idles fine but when you give it gas it bogs badly ...even worse when you try to WOT
please helped ...i've asked decently xp guys and they are stumped
please help been on this for 4 days STRAIGHT now :/
Old Jun 26, 2005 | 06:28 PM
Dragline's Avatar
Default Re: b20z problems help (CTRwannaB)
Did you try adjusting your TPS sensor?
Old Jun 26, 2005 | 08:11 PM
VTECVillain's Avatar
If you're not throwing any codes, check the timing. Actually check that anyway even if you are throwing codes...
Old Jun 26, 2005 | 10:01 PM
ADD TECH's Avatar
Default Re: b20z problems help (dragline)
did u cut any part of the harnes? cuz it going to be the tps change the green and yellow wires around
Old Jun 28, 2005 | 08:17 AM
CTRwannaB's Avatar
Default Re: b20z problems help (ADD TECH)
i didn't cut any wires but i did repin them....i looked in the book to wire it back up also.
gonna try reading the voltage from the tps next
thx for info
any other suggestions?
i heard that for b20z you havae to bump fuel pressure by 10psi?
lt1guy
Aug 5, 2010 08:23 PM
on-site ej1
Sep 22, 2009 09:08 PM
bsmith628
14
Aug 1, 2008 04:31 AM
92civicx
Mar 18, 2008 10:39 AM
Hatch-E
Feb 22, 2003 03:03 AM
