Axel fitment
Axel fitment
I am swapping my R swapwith 5 lug I had in a eg hatch back into a 97 R. What axels will work ?? The ones for the eg seem smaller.
Re: Axel fitment (BsmoothR)
4 bolt or 5 bolt conversion?
if 4 bolt, your oem shafts should work fine,
if 5 bolt, it might have the 36mm hub, in which case you need JDM ITR shafts, or your oem shafts with 92-96 prelude vtec outters
what engine is in your car? It should be fine for length because the itr hub ists int he smae place as the civic on did... only shaft length difference would be if you did a B-Series motor swap and tried to use the d-series axles
jdmcivR
08-13-2004 01:33 PM
chameleon
12
10-04-2002 10:22 AM
