Ls/vtec
Old Jun 26, 2005 | 02:11 PM
ADD TECH's Avatar
Default WILL VALVES HIT WITH B16 PISTON IN A LS/VTEC
will the valves hit the pistons if i use the b16 pr3 pistons with stage 2 CROWERS IN A LS/VTEC
Modified by ADD TECH at 10:29 PM 6/26/2005
Modified by ADD TECH at 10:33 PM 6/26/2005
Modified by ADD TECH at 10:37 PM 6/26/2005
Old Jun 27, 2005 | 05:01 PM
unknown0001's Avatar
Default Re: WILL VALVES HIT WITH B16 PISTON IN A LS/VTEC (ADD TECH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADD TECH &raquo;</TD></TR><TR><TD CLASS="quote">will the valves hit the pistons if i use the b16 pr3 pistons with stage 2 CROWERS IN A LS/VTEC</TD></TR></TABLE>
http://www.zealautowerks.com/
What is the max RPM your planning?
any head work or just a stage 2 cam?
Old Jul 23, 2005 | 01:59 PM
ADD TECH's Avatar
Default Re: WILL VALVES HIT WITH B16 PISTON IN A LS/VTEC (Mr.RHTuner)
HOW CAN YOU TELL THE DIFFERNCE FROM CIVIC TYPE R HEAD AND A NONE TYPE R HEAD
Old Jul 23, 2005 | 05:10 PM
PURPLETERROR aka BIGMATT's Avatar
no, they wont
Old Jul 23, 2005 | 06:00 PM
saleensolution's Avatar
Default Re: WILL VALVES HIT WITH B16 PISTON IN A LS/VTEC (PURPLETERROR)
an easy way to do it is to check your valve to piston clearance with some silly putty and manually engage it into vtec
Old Jul 24, 2005 | 02:53 PM
ntegnifong's Avatar
Default Re: WILL VALVES HIT WITH B16 PISTON IN A LS/VTEC (saleensolution)
no they wont hit cause thats the same set up i have. but id get better springs cause that caused my cam to break in half after 55.5 miles down the road.my coils binded
1A4
May 20, 2008 08:34 PM
WanaBeFaster
Feb 20, 2008 05:32 AM
watsvtecEK
Feb 16, 2006 10:01 PM
DOHC VTEC EG
Jul 5, 2004 11:17 AM
FLIPboi
Sep 19, 2002 05:13 AM
