K SERIES SWAP INTO EK ?'s
ok ok so i need this question answered... i want to do go k series in my ek and since i will probably be doing the swap myself (and with the help a few friends) i was wondering if i would encounter any problems since i am running a interior dash harness from an integra gsr... a shop by me used the whole harness to fit the gsr cluster (mind you this cluster swap was done years and years before the pin outs were available)... rewiring to stock would be sucha pain so im thinking if i had to rewire than i would say forget the k series and just go worked b18c-r...
thanks ahead of time
Re: K SERIES SWAP INTO EK ?'s (jdmek910)
if the dash harness is gonna cause that much concern... you could get another dash harness from another EK from a junkyard or something.. instead of rewiring it all back, just start over fresh.
but as far as u running into any problems... i guess that just depends on how good u are with the wiring...
Re: K SERIES SWAP INTO EK ?'s (hondaZvic)
thanks didnt want to go this route because the car is my daily driver and i know it would be off the road for a while
6SPD_EK
08-25-2004 07:57 AM
