B18C1 or B18C5????
Old Jun 13, 2005 | 06:39 AM
DC2R_GUY's Avatar
Default B18C1 or B18C5????
What is the best swap for the price?i have found the c5 for 4400 shipped with a year warranty and i found the c1 for 3400 with the same ship. is the r motor really worth the extra money or can i still get the c1 runnin quick. i'm not going to be racing it at the track or buildin a race car, i just want some speed and i would want to be runnin around a low 13 if i do race.
Old Jun 13, 2005 | 09:50 AM
EK FLY's Avatar
Default Re: B18C1 or B18C5???? (DC2R_GUY)
depend's on what u want to do with the car , what ur gola's are
c5 all the way if u have the money to spend it c5 is ur best choise ,
now if u want to get dirty and boots the engine get the c1 j0000!!!!
btw do a search
Old Jun 15, 2005 | 08:45 PM
IntegraGSR(-1)'s Avatar
they are basiclly the same thing..the same goals cna be obtained with them..here are the main differences...
type r has better valvetrain for higher revs...
type r tranny is way lower geared and will rap faster than gsr tranny..if you do all motor you want type r for sure...but gsr tranny is idle for boost...
and compression of coures...gsr is around 10:1 type r is quite higher...
Old Jun 19, 2005 | 12:57 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R_GUY &raquo;</TD></TR><TR><TD CLASS="quote">What is the best swap for the price?i have found the c5 for 4400 shipped with a year warranty and i found the c1 for 3400 with the same ship. is the r motor really worth the extra money or can i still get the c1 runnin quick. i'm not going to be racing it at the track or buildin a race car, i just want some speed and i would want to be runnin around a low 13 if i do race.</TD></TR></TABLE>
If you have to pay $4400 for the C5 and $3400 for the C1, then $4400 for the C5 is by far the better deal. You are NOT going to make a C1 equal a C5 performance-wise for the extra $1000. Furthermore, there is the issue of the transmission. There is just no comparison between the C1 transmission and the C5 transmission. With the C5 transmission (even pre-1998), you are getting gear ratios that are FAR more performance-oriented. AND you are getting a factory LSD. Just the transmission alone makes the C5 a MUCH better deal than the price difference alone suggests. The ONLY way I would go C1 instead is if you can find one ALOT cheaper.
Old Jun 19, 2005 | 09:40 AM
GetawayInMoscow's Avatar
Default Re: B18C1 or B18C5???? (IntegraGSR(-1))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraGSR(-1) &raquo;</TD></TR><TR><TD CLASS="quote">they are basiclly the same thing..the same goals cna be obtained with them..here are the main differences...
and compression of coures...gsr is around 10:1 type r is quite higher...</TD></TR></TABLE>
Everything is better about the ITR. Pistons, rods, crank, intake manifold, throttle body etc.
Old Jun 23, 2005 | 12:49 PM
Madspeed's Avatar
Default Re: B18C1 or B18C5???? (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">Everything is better about the ITR. Pistons, rods, crank, intake manifold, throttle body etc.</TD></TR></TABLE>
yup
Old Jun 27, 2005 | 09:16 AM
RS DC4 94's Avatar
Just curious, where did you find the c5?
Old Jun 28, 2005 | 01:38 PM
K I O K E N's Avatar
Default Re: B18C1 or B18C5???? (RS DC4 94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS DC4 94 &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, where did you find the c5?</TD></TR></TABLE>
Same that seems like a fair price. Not amazingly cheap, but fair.
Old Jun 28, 2005 | 10:53 PM
sickb16b's Avatar
Default Re: B18C1 or B18C5???? (EGSR)
It depends what you want to do. you can do GSR Swap and put a Nasty Turbo on it or do all motor Type R, but if it was me I would do the B18C5 swap. and then put a little more Money in to New Head Gasket to lower compression and turbo it.
http://www.teamxracing.com
2Nyce
Nov 9, 2010 11:19 AM
dj theoretic
Oct 30, 2008 10:18 AM
rotorhead187
18
Feb 14, 2004 11:50 AM
FlipboiGSR
Mar 23, 2002 11:15 PM
