poor mans type r ?
Old Jun 22, 2005 | 01:39 PM
02spoon's Avatar
Default poor mans type r ?
how fast is poor man type R, really.
stock gsr block stock b16a2 head
Old Jun 22, 2005 | 06:38 PM
sik civic's Avatar
Default Re: poor mans type r ? (02spoon)
The only poor man's type R I know of officially is and L/S Vtec.
A GSR's and Type R's Rod/Stroke ratio a diff. than an LS's.
I don't know what the outcome would be from using a GSR's bottom end.
Take a B18B block, put type R or B16A (higher compression) Pistons on it, and run a B16A head. Run Hondata and then you'll make as much or more WHP as a stock Type R.
I'm not a gear head but I can speak from my own experience.
Old Jun 23, 2005 | 12:58 PM
02spoon's Avatar
more info please
Old Jun 23, 2005 | 05:56 PM
sik civic's Avatar
Default Re: poor mans type r ? (sik civic)
depends what tranny your running, but with 173 WHP and running an LS tranny on street tires I could only pull a 15.025 1/4 mile run.
Old Jun 23, 2005 | 06:04 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02spoon &raquo;</TD></TR><TR><TD CLASS="quote">how fast is poor man type R, really.
stock gsr block stock b16a2 head</TD></TR></TABLE>
That is not a poor man's Type-R and neither is an LSVTEC... using a completely stock GSR bottom end with a stock B16 head would actually put the compression lower than a stock GSR. It's not a poor man's R without a piston swap
Old Jun 24, 2005 | 12:02 AM
02spoon's Avatar
ok so what if put itr or ctr pistons
how would that be
Old Jun 24, 2005 | 09:28 AM
bogus_ek's Avatar
Default Re: (02spoon)
if i'm not mistaken... all you would really need are jdm p30 pistons off the b16. according to some of the compression ratio calculators that should bring you to about 11:4 cr. but yeah do a search. most people doing this setup uses a gsr block, b16 head, different IM/TB, piston swap, and maybe a cam swap. usually end up with about 170-180 hp. In eg hatches, if i remember with good 60 ft times they usually net mid 13's slips. nice aggressive cams, and a good header are your secrets to making more power.
Old Jun 24, 2005 | 01:53 PM
sik civic's Avatar
Default Re: poor mans type r ? (VTECVillain)
My LS Vtec is a poor man's Type R then because I did the piston swap.
I used a B18B block with LS Rods and PR3 pistons. This yealded 11.63:1 compression for me.
93b16CivicSi's Avatar
that really sucks man b/c i have an ls tranny and i'm port and polishing my head with type r valvetrain, i really need to get a b16 tranny.
Old Jun 24, 2005 | 02:00 PM
sik civic's Avatar
Default Re: poor mans type r ? (93b16CivicSi)
Ya!
I swapped my LS Vtec out for a JDM B16A with DP Nos...love the tranny, miss the torque.
Old Jun 25, 2005 | 11:30 AM
PinkMaggit's Avatar
ls vtec
Old Jun 26, 2005 | 06:18 PM
jdmjeff's Avatar
Default Re: poor mans type r ? (PinkMaggit)
i have a gsr w/ ctr pistons, skunk 2 manifold (itr replica) tuned w/ hondata! compression should be around 12:5:1! i consider my motor a "poor mans R" well for one thing im poor!
Old Jun 26, 2005 | 07:08 PM
jdmjeff's Avatar
Default Re: poor mans type r ? (jdmjeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff &raquo;</TD></TR><TR><TD CLASS="quote">i have a gsr w/ ctr pistons, skunk 2 manifold (itr replica) tuned w/ hondata! compression should be around 12:5:1! i consider my motor a "poor mans R" well for one thing im poor! </TD></TR></TABLE>
yes/no what exactly is a poor mans R anyways
Old Jun 26, 2005 | 08:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff &raquo;</TD></TR><TR><TD CLASS="quote">what exactly is a poor mans R anyways</TD></TR></TABLE>
This is pretty much the recipe for a Poor-mans Type-R:
* B18C1/B18C GSR block
* PR3 B16 or ITR head
* PR3, CTR or ITR Pistons
If the motor uses an LS block with VTEC head then that's an LSVTEC, regardless of what's done/not done internally. Using a completely stock GSR block and B16 head is more like a Poor GSR due to the lower than stock GSR compression (about 9.6:1). You want the higher compression with a piston swap to get the ITR power output, unless you're boosting it that is.
Old Jun 26, 2005 | 08:23 PM
jdmjeff's Avatar
dont mean to ask all they n00bie questions here!
OK so compression is LOWER in a b16 head on a b18c1 block w/ ctr pistons compared to a stock b18c1 motor w/ ctr pistons sooo what you are saying (if im reading it right) is that a b18c1 motor is better ( or higher compression) than a b16 head on a b18c1 block right? hope you can understand my question
Old Jun 26, 2005 | 10:29 PM
jdmjeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff &raquo;</TD></TR><TR><TD CLASS="quote">dont mean to ask all they n00bie questions here!
OK so compression is LOWER in a b16 head on a b18c1 block w/ ctr pistons compared to a stock b18c1 motor w/ ctr pistons sooo what you are saying (if im reading it right) is that a b18c1 motor is better ( or higher compression) than a b16 head on a b18c1 block right? hope you can understand my question </TD></TR></TABLE>
anyone???
Old Jun 27, 2005 | 05:11 AM
bogus_ek's Avatar
well, the reason why people use this combination of b16 head on b18c block is because they are trying to put together a motor similar to a type r b18c5. the c5, all it really is, is a gsr block with higher compression pistons, and a b16 head with a port 'n' polish and better valvetrain and cams. Plus something like the b16 and type r head in general flow better than the one on the b18c. I know there have been tests to prove that the flow difference is very minimal, but there are the believers that say that honda used the pr3 cast for the type r head for a reason.
Old Jun 27, 2005 | 09:18 AM
jdmjeff's Avatar
Default Re: poor mans type r ? (bogus_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bogus_ek &raquo;</TD></TR><TR><TD CLASS="quote">well, the reason why people use this combination of b16 head on b18c block is because they are trying to put together a motor similar to a type r b18c5. the c5, all it really is, is a gsr block with higher compression pistons, and a b16 head with a port 'n' polish and better valvetrain and cams. Plus something like the b16 and type r head in general flow better than the one on the b18c. I know there have been tests to prove that the flow difference is very minimal, but there are the believers that say that honda used the pr3 cast for the type r head for a reason. </TD></TR></TABLE>
good **** but what about my set up? better than a poor mans R or worse... huuummmm...
Old Jun 27, 2005 | 10:35 AM
jdmjeff's Avatar
good **** but what about my set up? better than a poor mans R or worse... huuummmm...</TD></TR></TABLE>
anyone? i guess its just personal opinion!
Old Jun 27, 2005 | 12:10 PM
Got Milk's Avatar
i swear i was gunna make a post for " poor mans type r motor " but someone already beat me to it...my b16a shortblock is messed up and i need a new bottom end so i was going to get a 95 gsr shortblock...is this swap stock gsr bottom end with a stock 2nd gen jdm b16a head be slower than a actual gsr motor ?
although i still have my Pr3 pistons from my 2nd gen jdm b16a block but i dunno if i can afford a piston swap from a professional righ now
Old Jun 27, 2005 | 04:02 PM
bogus_ek's Avatar
Default Re: poor mans type r ? (Got Milk)
no, this is not a poor man's type r swap, this is just a beefed up gsr. good stuff though... like i said the difference in flow between the pr3 head and the one on the gsr is minimal. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Milk &raquo;</TD></TR><TR><TD CLASS="quote">i swear i was gunna make a post for " poor mans type r motor " but someone already beat me to it...my b16a shortblock is messed up and i need a new bottom end so i was going to get a 95 gsr shortblock...is this swap stock gsr bottom end with a stock 2nd gen jdm b16a head be slower than a actual gsr motor ?
although i still have my Pr3 pistons from my 2nd gen jdm b16a block but i dunno if i can afford a piston swap from a professional righ now</TD></TR></TABLE>
put your pr3 pistons in the gsr bottom before you do the install or else you end up with lower compression just like mentioned before. do a search for one of the compression ratio calculators. using the pr3 pistons in the gsr block with a pr3 head gives you about 11:4 ratio... don't quote me on that, but its something like that.
Old Jun 28, 2005 | 12:10 AM
jdmjeff's Avatar
put your pr3 pistons in the gsr bottom before you do the install or else you end up with lower compression just like mentioned before. do a search for one of the compression ratio calculators. using the pr3 pistons in the gsr block with a pr3 head gives you about 11:4 ratio... don't quote me on that, but its something like that. </TD></TR></TABLE>
good **** man thanks man for NOT being a dick about answering all our questions! thumbs up to you great info man
Old Jun 28, 2005 | 07:29 AM
Got Milk's Avatar
wut if u used the stock gsr pistons with a different head gasket to raise the compression would that work ???
Old Jun 28, 2005 | 11:01 AM
egsleepercivic's Avatar
^I believe the cambers on a b16 head are larger than on a gsr head, so even if you used gsr pistons with the b16 head it will lower your compression, unless you shave the head
Old Jun 29, 2005 | 08:47 AM
bogus_ek's Avatar
Default Re: (egsleepercivic)
yeah... that sounds about right... thinner gaskets only raise compression so much. remember the object is to get a motor as close to a c5 as possible, you you want to get the compression ratio as close to the c5 as possible.
