what ecu should I use for h22 in eg
I have a h22 running in a eg hatch. it is now running on a stock p28 ecu but is there a better way to run this or should I just chip it, if so where should I get the chip?
Re: what ecu should I use for h22 in eg (h22eg607)
You should have it chipped with an H22 basemap, and then dyno tune it to squeeze a few ponies out, if you have the coin.
P13 is what I am running. The only problem you will have with a P13 is a check engine light will come on going up hills for EGR (Exhaust Gas)
OBD1
OBD1
Re: (rpared01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpared01 »</TD></TR><TR><TD CLASS="quote">he can just connect the egr, the ecu just needs to know it there</TD></TR></TABLE>
If he goes with a chipped ecu (PR4/P06/P28/whateva) then the computah won't even look for the EGR, but it also won't run the IAB's.
just stick with the p28 and definately get it chipped and dynoed, i would talk to someone around where you live and find an import shop that has a dynojet or some form of dyno. if there cool they won't rape you on the price
Re: what ecu should I use for h22 in eg (JayWest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayWest »</TD></TR><TR><TD CLASS="quote">yup, p28 is your best bet</TD></TR></TABLE>
P28 crome tuned. Cheap and it works. i wouldn't run it on that stock p28 though. chip it and have it crome tuned. should run great.
oramac_eg
17
11-12-2009 02:11 PM
