* H23 problem PLEASE HELP *
Old 10-13-2007, 04:59 PM
Beans90crx's Avatar
Default * H23 problem PLEASE HELP *
Hey guys i really need help with my car, i have a 95 gsr with a H23a vtec swap and last night at the track while running my car i accidently went from 3rd gear to 2nd because my shifter is too loose, so i lost power and my car shut off. Now it will start but it shakes really bad and wont idle it will just cut off, and it sounds like there is no compression.
I removed the valve cover to check if it had jumped the timing but it lines up perfect.
If you have any ideas or suggestions id really appreciate the help.
Old 10-13-2007, 06:54 PM
I'm really 2slow
2fast4u831's Avatar
Default Re: * H23 problem PLEASE HELP * (Beans90crx)
do a leakdown and compression test. you might have bent some valves and/or a piston.
Old 10-13-2007, 07:00 PM
Beans90crx's Avatar
Default Re: * H23 problem PLEASE HELP * (2fast4u831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4u831 &raquo;</TD></TR><TR><TD CLASS="quote">do a leakdown and compression test. you might have bent some valves and/or a piston. </TD></TR></TABLE>
Im doing a compression test tomorrow hope i didnt bend anything but it doesnt sound to good.
And not to sound stupid but whats a leakdown test?
Old 10-13-2007, 07:08 PM
I'm really 2slow
2fast4u831's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beans90crx &raquo;</TD></TR><TR><TD CLASS="quote">
And not to sound stupid but whats a leakdown test?</TD></TR></TABLE>You need a compressor to fill the cylinders with air. this will tell you which part/s are wrong with the engine. intake valves, exhaust valves, or piston rings. It will shoot the air through the damaged parts.
Old 10-13-2007, 07:10 PM
Beans90crx's Avatar
ah ok well no compressor at home, but i have one at the sopw so i will also try that. Thanks.
Old 10-14-2007, 07:10 PM
Beans90crx's Avatar
Default Re: (Beans90crx)
bump for more help.
Old 10-15-2007, 11:58 AM
Beans90crx's Avatar
help help help
Old 10-15-2007, 02:04 PM
ESP.net's Avatar
Been here before same thing at the track H22 Crx...went from 3rd to 2nd hit 10k rpm and traped 14.1@80mph...I was fortunate to be able to drive it hope 60 miles and then took a dump... Valves are bent, if not worse... 99% sure thats your case as well...
Old 10-15-2007, 06:45 PM
Beans90crx's Avatar
Default Re: (ESP.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net &raquo;</TD></TR><TR><TD CLASS="quote">Been here before same thing at the track H22 Crx...went from 3rd to 2nd hit 10k rpm and traped 14.1@80mph...I was fortunate to be able to drive it hope 60 miles and then took a dump... Valves are bent, if not worse... 99% sure thats your case as well...</TD></TR></TABLE>
damn im gonna open it up next week hoping for the best but well see.
anyone know where to get internal parts for the JDM H23A?
Old 10-15-2007, 06:57 PM
The_Head's Avatar
It uses an H22A head right? So if the valves are bent...
Old 02-19-2008, 07:56 PM
Beans90crx's Avatar
Default Re: (The_Head)
ok so i finnaly got around to pulling the engine apart and all the exhaust valves are bent bad and exhaust valve guides are broken.
already sent the head to the machine shop and ordered H22a (p13) skunk 2 high comp. valves and got some other goodies as well.
Ill post some pics of the bent valves, might make this my build thread now.
Updates coming.
cammilian
01-09-2009 09:33 AM
Dave_Dc2
03-21-2008 05:35 PM
Lewdin' Incognito
06-07-2005 11:32 AM
mikester_91
03-12-2005 02:35 PM
Quick Reply: * H23 problem PLEASE HELP *
