need help with trans mount asap!!!
Old Sep 22, 2007 | 08:34 PM
atleast-3's Avatar
Default need help with trans mount asap!!!
i recently picked up a 95 ls that as i started gettin into taking things apart was converted from auto to manuel. my problem is that im trying to get the right trans mount. i bought a used hasport mount from a guy that had it in his eg with b-series swap. i went to put the engine in and the mount is like an inch away from the bolt lining up. do i need a special mount or something? theres lettering on the bottom of the hasport mount it says 'egamh'. should i get a mount thats from an integra or what?
Old Sep 22, 2007 | 08:41 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: need help with trans mount asap!!! (atleast-3)
yes, you need a special tranny mount for the auto-manual swap. Or you can buy the part of the chassis at honda and have it welded on your frame rail. I would suggest getting the part from honda and welding it These guys carry the auto-manual tranny mount. Both innovative and hasport makes them.
CAMP1320 INC.
9843 Mason Ave
Chatsworth, Ca 91311
818-718-9352 ORDER 818-335-5316 TECHLINE 818-773-9371FAX
Old Sep 22, 2007 | 08:50 PM
keithg's Avatar
The egamh mount from hasport will not work in an integra, you need the dcamh. The manual trans mounts are the same but the auto mounts are not because the b-series auto trans is a lot bigger than a d-series auto trans. Also when the previous owner converted your car from auto to manual did they change out the welded on bracket on the right hand frame rail? If they did you might have to change it back to the original as the frame rail is different on an auto integra and you can't just change the bracket like on an eg. I hope this helps.
Old Sep 23, 2007 | 12:07 AM
atleast-3's Avatar
Default Re: need help with trans mount asap!!! (keithg)
no i doesnt appear that the welded on bracket was touched at all. i guess i have to get the mount then. all the torque mounts should line up still right?
hondayute
Nov 13, 2007 08:47 PM
atleast-3
Jul 16, 2007 03:45 PM
90redintegra
Dec 8, 2006 06:17 AM
Danny_EJ
Sep 3, 2006 05:23 AM
