SI or GSR
Old Oct 5, 2007 | 04:32 PM
LsCivic18's Avatar
Default SI or GSR
I Have A LS Motor And I Am Wanting To Put A Vtec Head On It. My Problem Is I Dunno If I Should Go With A SI Head Or A GSR Head. I Have Heard That SI Flow Better. But Everyone I Know Has The LS/GSR Swap. Any Help Would Be Great Thanks
Old Oct 6, 2007 | 09:48 AM
leoaa777's Avatar
Default Re: SI or GSR (LsCivic18)
The differences between the two are nearly negligible.
Cheaper one is the one I would get. Plus with the GSR, you already have a pool of knowledge on your friends.
Old Oct 7, 2007 | 02:24 PM
SilvrBullet GSR's Avatar
well i dunno if it helps but i got a gsr block with a si head and that **** pulls hard stock... and ls is also a b18 1.8 liter non vtec.. well my best better prob would be the b16a2 si head, suspose to flow better too..
Old Oct 7, 2007 | 07:33 PM
LsCivic18's Avatar
I Know The GSR Head Pulls Ok, I Just Didnt Know What The SI Head WOuld Do On A LS Block. Im Wanting Something That Pulls Hard Stock. Im just Thinkin I Might Have To Go With A B20/SI Set Up To Get What I Want.
Old Oct 8, 2007 | 11:40 AM
LastGenEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsCivic18 &raquo;</TD></TR><TR><TD CLASS="quote">I Have A LS Motor And I Am Wanting To Put A Vtec Head On It. My Problem Is I Dunno If I Should Go With A SI Head Or A GSR Head. I Have Heard That SI Flow Better. But Everyone I Know Has The LS/GSR Swap. Any Help Would Be Great Thanks</TD></TR></TABLE>
A GSR head has a smaller cumbustion chamber. You will have a slightly higher cr
but the flow differenece is so small. they are both great heads in my opinion and a gsr head has a little more aggresive cams stock. but a gsr has the bypass valves so need a p72, the si has a better intake mani for high RPM. (im not posative on all my info im not 100 percent just trying to help)
Old Oct 8, 2007 | 01:40 PM
LsCivic18's Avatar
Well Since The GSR Cam Is Alittle More Aggresive Then Why Couldnt You Put The GSR Cam In The SI Head. The Reason I Say That Is B/C I Am Trading For A SI Head.
airikkCRX
Jun 8, 2007 12:46 PM
No
15
May 14, 2004 01:08 PM
Rob!
May 3, 2002 03:33 PM
MaD3 In JaPaN
Feb 28, 2002 04:44 PM
MaD3 In JaPaN
Feb 15, 2002 07:03 PM
