Help JDM Motor Troubleshooting.
OK, here is the problem.
I swapped a b16a sir2 into my 97 ex, i have an OBD2a P2T ecu (rare). everything is plug and play. I did a pretty clean swap, i have no CEL's and no check engine light. I sanded down all of the spots that the engine needed to be grounded to and cleaned them as well.
Problem:
At first the motor just turned over and over and then kinda rumbles as if it were going to start and dies. I went to Autozone and got some starter fluid and it started up (for the first time) with a horrible idle. I let it run for about 5-10 mins the idle only got a little better. thin white smoke was coming up. My exhaust downpipe isnt connected to cat converter yet but the 2nd o2 sensor is plugged in. so i assume the smoke was coming from the exhaust(carbon monoxide). There are no leaks under the car either. It idles at around 600-800 rpm. The idle is just really rough and boggy when i give it gas its still boggy. after i realease the pedal the idle drops and then #1 dies or #2 slowly reaches a steady idle. Its just really boggy.
Since the second O2 is inside of the unconnected cat, would this cause it too idle that bad?
I also used an old oil filter than had like 300 miles on it.
Any help would be appreciated.
Problem:
Re: Help JDM Motor Troubleshooting. (L337PCNOOB)
Replace the B16 injectors with your original EX injectors. They're the same size. What happens a lot of times with JDM engines is that the salty air and just from sitting for a long period of time, the injectors get clogged up.
Send the injectors out to RC.
OK So i replaced the injectors with my ex ones, it still runs like crap but just a tad bit better.....
Anyone else have suggestions. I think after i changed the fuel rail my fuel pump was making a wierd noise during the fuel priming.
prodjay10
31
03-20-2015 09:25 PM
mattsthru
05-27-2007 06:19 AM
